Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Mitsubishi victim I own a Mitsubishi WD 57732 and also a Mitsubishi WS65813 and they are both giving me problems. First, the WD57732 needed to get the heat sensor fixed since it kept turning off after 10-20 seconds. Then the bulb went out and now after replacing the bulb the image seems cloudy where it used to have a great picture. Second, on my WS 65813, the green light is flashing and it will not turn on. I am very aggravated and would appreciate some insight into these problems. Any ideas?
4 Suggested Answers
SOURCE: Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Posted on Oct 09, 2008
  • 7 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
jhinsincity
  • 616 Answers
SOURCE: wd 57732 won't turn on, power/timer light blinks
probably something related to the FMT board. will need shop service.
Posted on Aug 30, 2009
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
Mar 26, 2010 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 LAMP continuously burns out. I have replaced four in two years. We don't watch alot of TV.
There are a few issues here:
The lamp you are purchasing could not be OEM, or a compatible lamp--OR you have a ballast/power supply issue blowing the lamp out.
The original lamp is manufactured by Osram, but a better and compatible lamp would be Philips, who pioneered the lighting for DLPs. The ballast needs to be compatible with the lamp and Mitsubishi ballasts are compatible with most lamps, but work best with Philips and Osram. Only buy from an authorized dealer!
Feb 04, 2010 | Mitsubishi WD-57732 Projection Television
Wd 57732 won't turn on, power/timer light blinks
Aug 30, 2009 | Mitsubishi WD-57732 Projection Television
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Jul 30, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
