Question about Dell Inspiron 6400 Notebook
Multiple Boot on a Dell Inspiron Laptop
I need to install XP Pro, Unbutu, Mandriva and Vista on the same laptop. The problem is as I need to keep the Dell Media Direct Software I was costrect to prepare the hard drive with the Media Direct first and install XP Pro after, but for the rest of the above OS's what is the bet way (I mean witch first)?
I need those OS's to get more accostumised.
Thank you in advance for your help.
My Laptop is:
Dell Inspiron 6400
Intel Core 2 T7200 2GHz
4GB 667MHz Ram
Fujitzu 320GB Sata Hard Drive
(Partitions: 47mb FAT Dell startup, 195.31GB NTFS XP Pro, 100.73GB unpartitioned, 2.01GB Fat32 Logical Dell Media Direct)
TSSTCorp TS-L532U DVD-RW Drive
Ati Radeon Mobility x1400 256Mb Ram
  • Marco Flumino Jan 05, 2009
    Thank Wiz, but I really need to have them in the HD, for various reasons, my main problem is not the installations but the best way to do it, eg.:XP, Unbutu, Mandriva and Vista or XP, Vista, then the linuxes osses... And it will be any problem with the Dell Startup Partition?
    Thanks to try.
    Scholar:
  • 100 Answers
Invest in a couple USB drives and install the other os's on them. before you boot up plug in the apropriate drive and boot from it. Thats less complicated and painful to me
please, Let me know :)
Posted on Dec 24, 2008
Dell inspiron 1525 xp supported all free softwere
dell laptops running in windows xp and vista can install any free software as long the software is windows based like xp and vista.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Laptop won't boot into Windows XP
Did you do an upgrade or new install? Did you check the system requirements first to see if you could upgrade to Vista? This could all play a part in why it does not boot up. I suggest you reinstall windows XP again.
Jul 04, 2009 | Acer Aspire 5610-4648 Notebook
How to remove vista from 1525 laptop and install winxp
you have to get in Bios. you will find HDD section. it must be IDE/AHCI section. you need to do IDE if you want to install XP. XP doesnt regognize AHCI SATA drives.
May 30, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Dell Inspiron 6000 Laptop Won't Boot Up
The laptop won’t POST after removing the memory? Sounds like the memory module (s) need to be reseated again. Removing memory will not reset the laptop. If you want to install a clean Windows XP load, you need to boot from the Windows CD and format the hard drive.
Fell free to contact me if you need futher assistance.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell INSPIRON 6000 CENTRINO...
How do i downgrade vista bussines to xp if i only have the recovery cds
You need To purchase a windows XP setup install disk and serial, and boot from CD, performing a new windows installation.
Then you download drivers from Dell website.
Post the exact model for your laptop
Sep 22, 2008 | Dell Inspiron 1501 Notebook
Installing xp on inspiron 1525
The reason why xp does not see the hard drive durin setup is the ahci option enabled in the bios. you need to change the option to ata. to do that power on the system and tap f2 at the dell logo. in the bios change the stat operations to ata. the option most likely is listed under drivers. you may also have to disble flash cache from the bios. once the option is disabled hit esc and save and exit. boot from the XP cd and run the setup. at the partations screen delete the c drive and partation it according to the size you need for xp and leave the rest for vista. install XP and the drivers from support.dell.com. After XP is ready to use put in the Vista DVD once in XP and install Vista on the unpartationed space left from the c drive.
Rate if helpful.
Jun 03, 2008 | Dell Inspiron 1501 Notebook
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Vista to XP downgrade
If you did a clean install of Windows XP Vista has nothing to do with this problem. I infrequently have problems with Dell drivers not working but when I do its because I've installed the wrong ones. I have gone down the wrong troubleshooting path several times because the driver said it installed correctly..... I noticed that when you go to the Inspiron 6400/E1505 download page (http://support.dell.com/support/downloads/index.aspx?) you have the choice of selecting drivers from lots of OS versions including both 32 or 64 bit versions of XP. I would verify that you have the write driver versions and try again. Another alternative is using the drivers and tools CD that typically comes with a Dell. You can run that and it should have XP drivers. If you don't have the disk you can also try getting the network card running, connect to the Dell site and running their driver ID wizard to ID the drivers you need. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 20, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
169 people viewed this question
Alun Cox
