Question about SATO CL408e Thermal Printer
Printing When I go to print a label it only prints the first two lines of the label. My labele are 4x6 and it prints around 1x6 and I can't get it to print the whole label. This just started when we put in new labels. I checked the page setup in the program and it has the correct size of the label. We are using the Label Matrix program for windows. Any suggestions, Thanks, Robin Universal Tools & Mfg. Co. rmcelwee@utmfg.com
  • Anonymous Mar 24, 2014
    Can only print 50-100 labels at a time from database depending on label information. Do we need more memory?
    Problem Solver:
  • 20 Answers
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Posted on Aug 25, 2007
SOURCE:
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
I CANT PRINT THE CORRECT SIZE
Hi!
fixed the 203 dpi new head in zebra 105sl printer then 1 week print is correct size to 4x6 inches label but after 15 days its not comming full page print.
pls help to get soultion
thanks / Khokan
Jul 15, 2012 | Office Equipment & Supplies
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Zebra Eltron 2844 is not printing 4x6 shipping labels. I am using the printer to print FedEx labels. i recently had to reinstall the driver, and now when I print, it prints just under 2x4, rather than the...
You can recalibrate it to read the label size by doing the following.
Power off the printer
Hold down the green button
Turn the printer on and about 1/2 second after turning it on, release the green button
It will print out some information and measure the label. Once it stops, hit the green button one last time and then try to print another label.
Jan 26, 2011 | Office Equipment & Supplies
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
T5000 Thermal Printer
There are two guides on that machine.
One guide will make sure that the media is locked down and secured. if it isn't it will cause drifting.
There is also another guide around the thermal head before printing that guides the labels before it prints. It either white or or it could be a green color.
are you using the takeup roller on the printer to hold the wax paper? If you are is it straight on the take up roller?
Jun 11, 2008 | Printronix T5000 Thermal Printer
SATO CL408e Thermal Printer Logo
406 people viewed this question
Top SATO Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Argospete
Argospete
 steve
steve
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
