Sony PlayStation 2  Console
Problem for Sony PlayStation 2 (PS2) Console
Disc not spinning
By hode on Apr 13, 2007
Hi I have took apart my PS2 console to clean out the dust after I could not get the console to read disc I have notice that the disc was not spining it only did about a 1/4 of a turn at a time I looked on the internet but the only thing that they had was disc errror which is not my problem, it does not spin when I put in a disc if you can help me please email me at steve_87@hotmail.com TY
Comments:
Apr 13, 2007
- Thank you but i do not understand,do I have to buy something? Or could it be an adjustment on the console? On the PS2 SCPH-30001 R next to the laser eye in front of the console that spins the disc which is not spining is what I have to replace?
Apr 14, 2007
- What does the laser have to do that the round disc is not spinning? If I keep hitting the button to open and close the tray about 10-15 times it will start reading the disc,and then I can play the game could the it still be the laser or something else? TY
Apr 17, 2007
- TY for the reply i will ask you how to do that if you don't mind?
Same Problem
May 18, 2009
-   My PS2 was working fine until today. Now the disk won't spin and it goes strait to browser mode. if anyone has any answers PLEASE e-mail me at patrickyeck@gmail.com THANKS! -   patrickyeck
Feb 28, 2009
-   ps2 turns on and goes straight to browser menu.if i restart the system with the game or dvd in it ,it says reading disc then says "unable to read disc". the game fell about 1 1/2 feet when someone tripped over the cord and pulled it off the table it was sitting on.is there something i can do to fix this.oh and the disc only spins about 15 seconds -   carla1scorp
Feb 27, 2009
-   the disc does not spin-   chrisboy11
Feb 26, 2009
-   today i have took my PS2 apart cause the disc was not spinning. Also the eye was not doing nothing. When i try to take the tray out it would make a grinding sound.Someone help me?????-   Guest
Sep 06, 2008
-   when i put a disc into my ps2 sometimes it works but it usually dosen't what do i do?-   wil23
Best Solution
posted on Apr 23, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you may need to remove the entire disc componet from the unit, check the underside of this, and make sure that the wire is properly inserted into its holder.
Solution #2
posted on Apr 13, 2007
Helpful)
Arpi
Rank: Guru  Sony Expert
Rating: 86%, 667 votes
please check the model of the optical unit and purchase the new (original) one. Then you can change the optical taking care that mechanical alignment should stay the same as before replacement.
Hope that this will solve your problem.
Best regards,
Arpi
Comments:
Apr 13, 2007
- Yes, actually laser is to be replaced. But if you are not certain in your skils please ask someone to do this for you. One can not adjust when there is a broken part - that is a general rule.
Best regards,
Arpi
Apr 17, 2007
- Hello,
here is the answer to your last comment. Inside the PS2 there are some sensors (micro swtich) that sense the position of the lift (in or out). Cleaning or replacing them as well as the belt that drives the lift can solve your problem
Best regards,
Arpi
Was this helpful?
Yes
No
Solution #3
posted on Aug 07, 2009
Not Rated)
lailaha
Rank: Master
Rating: 79%, 23 votes
Try this link . . . http://www.Sony.com/PlayStation2PS2Consol
To find your best solution.
10
Was this helpful?
Yes
No
Solution #4
posted on Jun 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i need help to u know
Solution #5
posted on May 11, 2007
Not Rated)
Maxivideo
Rank: Apprentice
Rating: 0%, 0 votes
The driver's motors IC is damaged
Was this helpful?
Yes
No
Solution #6
posted on Apr 30, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
T Y I just cleaned the lens and it work fine now thank you for the help
Popular Solutions for Sony PlayStation 2 Console
Questions and Unsolved Problems for Sony PlayStation 2 Console
Do you recommend Sony PlayStation 2 (PS2) Console?
Answer
Answer
how to get playstation 2 live
Answer
don't know how to save high scores to memory card
Answer
I'm playing Mana Khemia 2 and when I save the memory card is corrupted and then I can't use the card... (More)
Answer
The electric strip that connects to the reset button has come apart. how do i fix it
11 Other Users Have The Same Problem - Continued
Comment by phurysmate, posted on Aug 21, 2008
DISC ONLY SPINS FOR A 1/2 MINUTE, MESSAGE ON SCREEN SAYS CANNOT READ DISC AND MENU STAYS IN BROWSER MENU MODE.
Comment by Guest, posted on Jun 20, 2008
my ps2 reads all of my other games but not rockband
Comment by lild959, posted on Jun 15, 2008
my playstation 2 is acting all wierd. i have tried diagnosis and cleaning it but it still won't work. its ticking me off. someone please help me!!!!!!!!!
Comment by mikey3rd, posted on Jun 14, 2008
i've tried all my games and it only spins for a few seconds and stops spinning.the console says "disc could not be read".
Comment by kimmy0325, posted on Nov 26, 2007
I have a PS2 unit and having problems with disc not spinning. When I power on unit it makes noise and attempt to start but does not turn disc. I ordered a new spinning unit and it still will not turn. Is there another part I need to replace?
Comment by PearlZ, posted on Nov 16, 2007
the console is not reading any data and its not spinning
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony PlayStation 2 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
