Question about Lexmark X2350 All-In-One InkJet Printer
Feeder Messes Up
The feeder always rolls to one side when feeding pages.
  • 829 Answers
Hi , I suppose the problem you face can be due to driver problem , Reinstall the driver and check for the paper tray if any paper is stuch ( Jammed )
Posted on Dec 25, 2008
Document feeder won't feed.
Did they replace the rollers and seperation pad/roller? They replaced the Clutch but not the rollers odd. Also might ask about having the feeder firmware checked updated. or the control board replaced.
Dec 10, 2015 | Sharp AR-M257 Black and White Copier
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
Printer header path type 1, 2, and 4 prolem request for feeding back
If the media does not feed into the in-feed slot in the media cabinet, try the following:
  • Make sure both roller levers are lowered to open the in-feed slot.
  • Trim the leading edge of the paper so it does not get caught in the slot.
  • Insert the media evenly to avoid angles. Do not insert one corner and then the other.
    NOTE: A beep means that the printer has detected the media in the in-feed slot. The printer will only beep once in a load cycle, if media is removed and reloaded the printer may not beep again if the load process is not re-started through the front panel.
Media does not advance If the media does not advance far enough into the in-feed channel in the media cabinet, the paper is slipping and the rollers do not grip the media. Try the following:
  • The pre-tension might be applied incorrectly. Always apply pre-tension by turning the star screw on the left side of the spindle. Never apply tension by turning the media roll or the spindle disks.
  • Clean the rollers using the cleaning procedure.
  • If the media being used is heavy coated, try changing the media.
Media jam in the in-feed channel If there is a media jam in the in-feed channel, try the following:
  • Turn the multi-roll feeder off using the power isolator switch on the connector panel at the back.
  • Open the media cabinet doors and lower the roller lever on both sides.
  • Turn the spindle to pull the media out of the in-feed channel and to collect it back on to the roll.
  • If the media is blocked, place the spindle in the park position for better access to the in-feed channel, and then pull the media edges in a downwards direction on both sides.
  • If the media cannot be reached because the roll has finished and it has not been ejected from the front of the printer, open the rear cover and try to remove the media from the motion control assembly.
    NOTE: Do not insert media with crumpled or damaged edges, trim the media first.
  • Make sure the leading edge is trimmed straight.
  • Make sure there is even tension across the width of the media.
  • Make sure media is aligned (the same amount of media is fed across the width).
  • Apply pre-tension the media.
When the printer is going to be unattended for a long period of time, it is a good idea to load and unload each roll using the LOAD/UNLOAD commands from the front panel (if the media loading procedure was not completed when prompted by the printer). This will ensure that each roll of media loaded is correctly aligned and that the printer is capable of loading/unloading each roll when requested by the print jobs in the queue.
Media misaligned When a "Misaligned?? message is displayed, the printer unloads the media. Press ENTER to continue and the printer will display the "Ready for paper?? status message. Do the following:
  • Check for even tension across the width of the media. If there is less tension on one side than the other, then the media is not straight in the in-feed slot.
  • There is a hole on the right side of the in-feed slot. Make sure the edge of the media is aligned with the left side of this hole.
  • Lower the roller levers on both sides and adjust the media so that tension is even across the whole width. Turn the spindle disk quickly two or three times away from you and then two or three times in the opposite direction. This will help to create an even tension.
  • Lift the roller levers on both sides and try to load the media again.
If this does not solve the problem, remove the media from the in-feed slot and repeat the loading procedure. Make sure the roll is against the right hand spindle disk (fully inside the roll core), and do the same for the left hand spindle disk. The printer verifies correct alignment using the blue line on the right hand side of the printing area as a reference. Media does not unload correctly If the media does not fully unload from the in-feed channel in the media cabinet, check the following:
  • Maybe there is not enough pre-tension. Always apply pre-tension by turning the star screw on the left side of the spindle three or four times (or more if the spindle is on a low retainer bracket). Never apply tension by turning the media roll or the spindle disks.
  • The spring applying pressure on the retainer bracket is loose and the spindle is slipping in the retainer bracket. Turn the multi-roll feeder off and turn the retainer bracket screw one turn in a clockwise direction.
Partial or blank prints If the print is partial or blank, check the following:
  • Check the multi-roll configuration in the printer driver: Check that the Has Multi-Roll Feeder check box is selected.
  • Check default roll configuration: Check if a roll is installed for the roll configured as default. If a roll is not selected from the printer driver, the printer will try to print to the default roll, and if no identical roll is available, it will not print the job.
  • Check Productivity mode settings: If the mode is set to normal and the roll has finished, the job cannot be printed.
  • Check cable connection: Check that the printer and any network cables are securely connected to the printer. Make sure the parallel cable is connected between the multi-roll feeder and the printer and ensure that it is also firmly connected between the computer and the multi-roll feeder.
  • Check media configuration: Make sure the media rolls are configured correctly.
  • Check document file: When printing files that are generated with versions of printer drivers for printers without multi-roll feeders, the header section of some file formats already contains information on the media. In these files, roll or sheet information corresponds to roll 1 in the multi-roll feeder. These files will print to the Default Roll. HP advises that the top roll (roll 1) is used as the default.
Dec 09, 2010 | HP DesignJet 1050c plus InkJet Printer
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
HP 3050 All-in-One printer feeder problem - followup ?
under scanning tools / settings check for double feed detection (enabled / disabled ) if not found, for feeder side replace pad assembly the one that hold paper to double feed.
Mar 23, 2010 | HP LaserJet 3050 All-In-One Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
Lexmark X2350 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
