Question about SansuiS3245 TV
Using TV as external monitor
I bought an Svideo cable with an Svideo plug on one end - to go into my laptop - and an RCA plug on the other end to plug into the front of the TV. I plugged it in and 1) it distorted the display on my laptop and 2) I didn't get any display on the TV in either Aux1 or Aux2 modes. What do I need to do?
  • Nancy Nuce Apr 14, 2007
    Thanks anyway, but I'm afraid you are mistaken.
    After some more research, I found out what to do. I had to download a driver from HP for my laptop and then "toggle" the fn-f4 keys to get the picture to display on both the TV and the laptop at the same time.
    As for the distorted display on the laptop, this was fixed by going into the "advanced" section of the display options and re-setting the settings.
    All's well that ends well!
    Genius:
  • 1,074 Answers
Your are getting some signals feed back to your computer which damage your computer.it wont work you will have to get a computer monitor to do the job good luck.
Posted on Apr 14, 2007
SOURCE:
How can i connect my laptop ibm R51(2887) AE3 to TV using svideo cable
Hello - It's really fairly simple. You need the S-Video cable and if you want sound a 3.5 mm stereo cable with whatever connector on the opposite end that your TV requires (probably stereo RCA male connectors.)
Here is an illustration direct from IBM about setting up the R51 to TV connection:
Enjoy and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Computers & Internet
Not able to connect my cable reciver to my rca L32HD31R
  1. Connect the RCA Output on you Cable Receiver to the RCA Input on your RCA TV, taking note of which Input you plugged into, e.x. DVD, GAME, etc.
  2. Turn on your Cable Receiver, and your TV.
  3. On your RCA TV, change the Input to the Input you plugged your Cable Receiver into.
  4. You should now be able to change channels using your cable box, and view it on your TV.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 01, 2011 | RCA L32HD31 32 in. LCD HDTV
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Picture is black and white with a dvd movie
If you're using the 3 component cables for video, one is probably defective or not connected well.
Dec 29, 2009 | Bose Lifestyle 38 System
I am using a SVideo cord to connect my laptop to the tv. I have changed the input to both video 1 and video 2 and it is saying Unusable signal.
did you turn on your external video on the laptop?Usually a combination of keys i.e;FN+ one of the F key, it will have a little tv screen logo on it.Or connect your cable and reboot your laptop.let me know if it helps
Nov 02, 2009 | RCA 27V530T 27" TV
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Plugging my IBM T60 with a VGA - RCA Cable
does the laptop recognize that an external device is plugged in when you connect? you should hear a beep and be given options to adjust video settings. look at your keyboard and look for the picture on one of the keys (either number keys or fkeys) for the display change button. you usually have to hit the fn key and then the corresponding key.
iv had issues with this personally going from video out to svideo to rca video and ended up losing color...adapters are funny things. its possible that the adapter itself either doesnt work at all or just doesnt work with your laptop. wouldnt be the first time.
Mar 28, 2009 | Dell Inspiron 2200 PC Notebook
I have the RCA RT2500 model and I am looking for directions to connect tv, DVD, gaming, Cable Box, etc are there anywhere on line I can find it? thank you
the back should have a squared in box around the inputs like dvd vcr sat tv cd, dvd and sat have svideo and component a/v plugs, the vcr just has component rca a/v ports, tv and cd are just for audio, then you also have the option to hook up optical for dvd and sat. just plug your vcr into the vcr box and hook up svideo or the yellow monitor out plug to your tv, hook in the speakers and turn that baby up.
Jan 07, 2009 | RCA RT2500 System
Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Jan 05, 2009 | Computers & Internet
HP Pavilion dv2500 no display when power lights not blinking
Hello
To get the display on the TV . Please press Fn + F4 after connected TV to the Notebook using Svideo cable and the cable should be connected to the Svideo port of the Notebook.
If there is not display on the Notebook after the Svideo cable burns.
Then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists then check whether the display is same on the external monitor.
I hope this will work.
Thanks
Aug 24, 2008 | HP Pavilion dv2500t Notebook
SansuiS3245 TV Logo
213 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
