Question about Dell Pocket DJ MP3 Player
My Dell Pocket DJ won't connect to my computer
I plug it in like normal but the computer doesn't recognize the player. It doesn't show it's connect to the computer. And the sound it makes on connecting is abnormal. I've never had this happen before. The player also does not say say it's 'docked' like it used to.
  • 2 more comments
  • mabonifas Jan 05, 2009
    ill plug mine in and it will not say it is connected on my computer. i have tried it with it on off locked unlocked nothing seems to work.
  • gamalielpena Feb 18, 2009
    After installing the software of dell 20 in my laptop from dell site, the computer does not recognize the dj and say {,yor dj is not connected.
  • kbizjak Feb 27, 2009
    My Dell Pocket DJ won't connect to my computer, it used to work fine, now it says it needs a device plug-in. I tried to go to the Dell website but the downloads won't work. Help!
  • Anonymous Apr 04, 2009
    Plug it in, it says it's docked. All the drivers are installed, but it won't connect and the player won't work.
SOURCE: Dell DJ (Generation 2) not being recognized by computer
Found the answer on Dell Forums. A lot of Dell DJ folks have been having the same issues. The problem is with Windows Media Player (shock). The Windows driver dated 2006 is installing itself and taking over, not allowing Dell's 2005 driver to work. The bottom line is the DJ will dock but not be recognized by your computer, Windows Media Player, or Yahoo Music Jukebox.
To check to see if this is the issue dock your DJ then click on start, right click on my computer, and then hit properties. Click on hardware tab and go to device manager. Look for portable devices on the list. You will likely see your DJ with a yellow (!) next to it. Right click on the DJ and hit properties again, then look in the driver tab to see what driver is listed. If you see a driver with the date 2006 or newer, then Windows is screwing you up.
The only way I've found to fix this is to either uninstall Windows Media Player or go back to an old enough version that the 2006 driver is not in the system. The 2006 driver is from Microsoft and somehow it interfers with the proper driver, which is from Dell and should be dated either 2004 or 2005. Once Windows is uninstalled completely, or back to an old enough version that you are safe (I am not sure how far back you must go, I just uninstalled the darn thing completely), you need to uninstall the Dell driver then go to Dell's website and reinstall the latest. Also make sure you have the latest firmware.
It sounds like a lot of work but it honestly took me longer to type this note that to do it and I don't have a clue what I'm doing. It's better than throwing away your DJ. From the comments I saw on the Dell Forum, Dell is not aware of the issue and isn't much help. Many people spent hours on the phone with Dell support only to hit a dead end and get the recommendation to replace the device.
Hope this helps all. A huge thank you to the folks over all Dell Forum who figured out the solution despite Dell's technical assistance.
Posted on Apr 22, 2008
  • 758 Answers
SOURCE: re: Computer recognizing USB connection to dell dj
Go into your Start Menu and right click on My Computer and choose "Properties" from the menu. Click on the Hardware tab on the new window that opened. Select Device Manager. Check to see if your device is recognized under Windows Portable Devices. If your device is not recognized here,what i would recommend you to do is to uinstall the device.
To uninstall the devid just right click on the device name and hit uninstall...the device usually listed under disk drives, portable devices and univeral serial bus controllers.. Once you uninstall the device..you will need to make sure what mode you have the device...turn the device on and click under setting and look for usb mode...then you want to make sure its under MTP mode or Auto....then what you will want to do is to plug the device on that back of the computer not the front...then windows should recognize it...if that doesnt do it you will need to contact the manufacturer of the device.
3. Open Windows Media Player and go to the Sync section. It should be recognized on the right-hand side. If it is not, or if your device has a drive letter after its name (for example F :), your device is not being properly recognized by the computer and you will have to contact the manufacturer of the device.
4. If it is seen in Windows Media Player then disconnect the Device and close all programs.
Next we are going to make sure that Windows Media Player is not storing unnecessary information about your device:
1. Open Windows Media Player.
2. Maximize the program and choose the Tools > Options menu.
3. Click on the Privacy Tab in the open window and choose "Clear Caches" and "Clear History".
4. Re-connect your device and choose "Manual" and "Permanent" on the window that opens.
5. Close Windows Media Player.
I hope that help...
Thank you
Computerrep
**Please rate accordingly...**
Posted on Jan 29, 2008
  • 758 Answers
SOURCE: dell dj
I hope that help...
Thank you
Computerrep
SOURCE: dell dj firmware
I had the same problem and it turns out the firmware did get loaded, the program just didn't close out properly. If you go to Settings & Info-->Information on your DJ you should see that it is the updated version.
Posted on Feb 21, 2008
SOURCE: make vista recognize my dell dj 20 gig
weet iemant
Posted on Jul 16, 2008
Running windows 7 home on one PC and windows 10 on another. I don't have the installation disc anymore, and the drivers I downloaded from Dell don't seem to work.
Daisy Mae,
The Pocket DJ is not compatible with Windows 7 or Windows 10. If you plugged it into your computer and it did not recognize the device or show up in "My Computer' then it will not work. You would need a windows 7 and Windows 10 drivers.None are available..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 01, 2016 | Dell Pocket DJ MP3 Player
I am running Windows 8.1 on an Inspiron 15 64-bit machine. I need software for my Dell Pocket DJ 5GB. When I connct th DJ to the PC there's a tone as fo the PC recognizes the device. However, the device...
I think your Dell pocket DJ is an XP based Operating system.
1 press the start button
2. go to all progams and choose windows update and update your laptop
3. when the update is done, restart your system and try again.
Please tell me the pocket version you are using?
Mar 15, 2014 | Dell Pocket DJ MP3 Player
Dell DJ 30gb not recognized in vista
try using a different usb cord and u can also use songbird to put songs on it
Aug 16, 2009 | Dell DJ MP3 Player
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
Jan 28, 2009 | Dell DJ MP3 Player
Dell Pocket DJ 5gb music problem
i need a drivers for my pocket dell dj 5GB model number HV03T
Aug 07, 2008 | Dell Pocket DJ MP3 Player
Dell pocket dj 5mb wont turn on
there is a pin hole to reset it.On the botom side beside the dell logo you will see it.Use a pin to reset.
Good Luck
Jul 07, 2008 | Dell Pocket DJ MP3 Player
No recognition
same here - when I first got my DJ it took some time to get all the correct fixes and downloads but i got it going and it was great.
My hard drive crashed... now I'm trying to download the software again to get more songs on it, etc. and it is not being recognized... where is THIS fix?
Nov 13, 2007 | Dell Pocket DJ MP3 Player
Make vista recognize my dell dj 20 gig
Try downloading the newest firmware to your Dell DJ
Nov 12, 2007 | Dell DJ MP3 Player
Dell Pocket DJ MP3 Player Logo
687 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
