Question about Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater...
Keep getting error codes and have to reset too often
I have a Bosch GWH 715ES tankless hot water heater. While taking a shower the tank flashes an error code of A3 and E3. Of course the water immediately goes cold. Getting in and out of the shower to reset several times is not fun. Any suggestions on what the problem may be?
  • Anonymous Jan 04, 2009
    Same problem here. Bosch hot water heater GWH 715 ES. Error code E3.
  • Anonymous Mar 28, 2014
    Water is cold occasionally
  • 25 Answers
This paticular problem your having is specific to the jumper in the heater. The jumper is for condensing heaters. Your heater does not have the specific wiring or computer for condensing. So they added a jumper in the wiring. It is failed or failing. It should ohm out at about 120ohms. sometimes its just a loose connection. Check this out, and called 1-800-642-3111, they have been very busy, but leave them a message and they will call you back.
Posted on Jan 19, 2009
  • 700 Answers
Here is the link for that particular model the you have and it has the solution for the a3 code but according to the manual the E3 code does not exist. You may have to contact Bosch for additional assistance. Thanks for using FixYa.
http://www.protankless.com/Portals/10/TechManuals/GWH715ES_English_04_2008.pdf
Posted on Dec 25, 2008
  • 3 Answers
It is a bad controller board.  You need to get them to replace it.  E3 doesn't even show up in the Technician Manuals.
Posted on Mar 07, 2009
I had the same problem. First try to disconnet the air inlet line right and the hot water. This will draw the house air out but it might work. Manual says the inlet and exhaust can be up to 26 feet but not always the case.
In my case I had to change my exhaust pipe in the attic that had two 90's connected. Came through the sealing, 90'd toward the outside vent pipe then 90'd up and out the roof. So my total exhaust line was, 2-45's and 2-90's but I still was within the manual specs of 26 feet. I changed this to run straight out my roof which eliminated the 2-90's in the attic and now it works perfect.
Posted on Jan 14, 2009
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
Jan 02, 2014 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch gwh 425 hn
Fix problem immediately same day, yourself, for $385, by replacing whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Bosch posts some service manuals: or contact Bosch. Lack of error code indicates failed PC board? or bad single-handle faucet cartridge?
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Check for crossover where bad faucet cartridge allows cold water to enter hot pipe, so hot water is not drawn through tankless and burner does not activate... but this might not be problem since you hear the tankless clicking
http://waterheatertimer.org/Crossover.html
Call local service technician to catch up on required yearly maintenance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 09, 2013 | Water Heaters
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 2700 CTDR EFS NG and the water will not get hot and if it does, it's only for a brief moment.
A lot of factors, internal and external, can cause this problem ranging from bad PC board to plumbing problem.
Since you have no error code, it could be plumbing,
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open following link for useful Bosch troubleshooting information including Bosch support and typical manual for 2700 gas tankless:
For folks with Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
I have a Bosch GWH 2400 CTD EFS NG tankless water heater. It has been installed on operating for over a year in the last several days it has an error code A3. The first two times I was able to reset it....
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Mar 18, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch manuals:
Mar 17, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
EA error msg on Bosh tankless unit
How I fixed it was got rid of it...support help never called back..and to get parts for it was looking into the new year can't go without a shower that long...can we now?
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
1,287 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
