Question about Pioneer SD-P5795W 57" Rear Projection Television
Power Supply part problem with a SD-P5795W
I have a SD-P5797W projection TV.  It was not working properly.  When it is turned on, it turns itself off.  The reld light goes orange for a sec then turns back to red.  I had a repairman out and he said that it was the "power supply?". He was going to try find the part thru Pioneer.  He never called back nor would he give me the part he was trying to find so I could find one myself.  He said that the rest of the tv is "in perfect condition".  I do not want to buy another one if I can get this one fixed.  Where can I find the part number to obtain and/or have someone find and fix it for me.  Thank you in advance for any help you can give.   There is a date of 3/1998 inside. Clare Ann
  • 3 Answers
I wouldn't trust anything this repairman said reason well for one thing how could he (or anyone) tell everything else is "in perfect condition" when he couldn't "see" anything to tell what it looked like. He might be right about the power supply being bad But it could also be the high voltage "power supply" could have a short and that would cause the symptions you describe
But if you want to try the power supply your self you can call Pioneer and give them the model number and they should be able to get the information you need.
tvkirk
Posted on Nov 24, 2009
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Tv runs through vcr only. What can we do? Also need a manual. Where can we find one?
try to resolder the tuner first and see if that makes a difference , otherwise you may need to replace the tuner
does video inputs work ok?
Nov 07, 2008 | Pioneer SD-P5795W 57" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
TV turns on and off and changes channels on its own. tv pioneer 45 in projection when you turn the tv on it will turn off
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board. also check for any loose soldering joints on the main board. calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
Jun 18, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
50" Projection TV
your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Feb 24, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Need help
A power supply is a very complex circuit that changes the voltage that comes from an outlet to voltages the tv can use and is a circuit that need to be repaired because in Tv's is only a section of a circuit board and the rest of the board has other functions. Computers use a single module that you can replace as a whole but not tv's.Be safe an call a qualified technician because there is danger involved.Get an estimate.
Sep 17, 2006 | Pioneer SD-P5795W 57" Rear Projection...
Tv works and then shuts off after being on for various amounts of time
Some where in the power supply is a bad capacitor. The only way to fix this problem is with a good capacitor checker and the circuitry know how on finding bad componets. Its not really a job for the do it yourselfer. Sorry . Seel out a pro to assist you in this repair. Good luck
Aug 21, 2006 | Pioneer SD-643HD5 64" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P5795W 57" Rear Projection Television Logo
123 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
