Question about Philips 32PF7321 32 in. HDTV-Ready LCD Television
Philips LCD TV wont change aspect ratio
I have a Philips 32" flat screen HD ready TV. When the TV is hooked up to my Sky HD box I cant change the aspect ratio thru the HDMI link; I have to switch to the SCART link if I want to watch a non-HD channel that is broadcasting in anything less than 16:9.
  • 325 Answers
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Little Dish Fitter
Posted on Sep 02, 2009
  • Mick Sep 02, 2009
    Job done
    Little Dish Fitter
4 Suggested Answers
  • 10515 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
Folowing is the link for the service manual for FLU 1911 s :-
I hope it wld help u :)
Posted on Nov 25, 2008
SOURCE: LG 32'' LCD TV aspect ratio self switching
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Massimo Moruzzi
Posted on Nov 30, 2008
  • 20 Answers
SOURCE: Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Posted on Jun 01, 2009
Haier tv I am hooked into Bell Expressvu. HD receiver and I can't get the picture to expand to the entire tv screen. i can only find HD Normal and it stays in a small screen view.
It might be necessary to change the resolution/Aspect Ratio (Screen Size) settings on both your HD Receiver and your TV.
I don't have Bell Satellite but I do remember having the same issue setting up my friends HD TV and Bell Satellite TV Receiver.
Nov 25, 2013 | Haier HL32D2 32 in LCD TV
How to change aspect ratio on lg rz-32lz55?
Any chance you are using a box with this set for signal?
Dec 17, 2012 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Jan 10, 2009 | LG 32LG30 32 in. LCD HDTV
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Philips 32PF7321 32 in. HDTV-Ready LCD Television Logo
1,669 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
