Question about Whirlpool AWM5125/1 Front Load Washer
Whilpool front end loader leaks water after done filling
Water leaks from where water fills drum.
  • Anonymous Apr 23, 2009
    can i fix myself or should i outsource,leaking at base of washer after wash
  • 640 Answers
Theres a hole in gasket (bellows),,,,now also check your detergent draw if water pressure is to high it will splash over and come down inside of cabnit...
Posted on Dec 24, 2008
Why does my front load washer not fill up with water like top load washers
Most modern washers use little water. Let it do a wash cycle and see if the results are satisfactory. If not good enough there is a way to allow more water to be used. Give it a go first.
Aug 29, 2014 | Whirlpool duet Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Leaking washing machine
Need more information. What type of leak (fast, slow, seep, etc.), when does it leak (when it is filling, draining, all the time, or don't know), and where is the leak coming from? If water runs out as fast as it is filling, you may have a drain hose that is ruptured or has disconnected. If it is a very slow leak, you may have a connection that is working loose. Or, it could be as serious as a hole in the outer drum. Is this a top loader or a front loader washing machine?
Apr 10, 2014 | Maytag Washing Machines
Front leaking
It sounds like you are over-filling the drum with water. Check the fill switch. If the fill switch is bad, it will not stop filling with water.
Mar 18, 2012 | LG WM2042 Front Load Washer
Whirlpool Duet:drum fills up with water when machine is off.
Your problem is the water inlet valve has failed part # AP3128776 This is fairly common especially if you have hard water or well water.
Just enter that # at www.appliancehelponline.com
Mar 24, 2010 | Whirlpool GHW9400 Duet Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
Water all over floor. Replaced broken door latch. Still leaking. removed front bottom panel. it looks like water is coming from the drum???
it sounds like a door seal problem ,its normal when wter is comming from drum most front loader fill by spraying water on drum,you may also want to check drain hose it could be kinked or pluged up,se what this does and clean filter if you can get to it.
Dec 16, 2009 | Washing Machines
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
Jun 11, 2009 | GE WSXH208A Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
136 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
