Computers & Internet Logo
Anonymous Posted on Dec 24, 2008
Battrey voltage low
On my computer when i sighn in it says battrey voltage low my computer type is dell gx280 and it say f2 to bootup and f1 to proceed
Anonymous
Level 3:
  • Master 741 Answers
  • Posted on Dec 24, 2008
Anonymous
Master
Level 3:
Answers
741
Questions
Helped
287670
Points
2256
The only battery in a desktop is the CMOS battery. This is a small round battery, looks like a watch battery and it is on your motherboard. The battery keeps a small amount of electricity going when your computer is turned off so that the clock and date can be kept current. If you take the cover off of your PC you will see it on the mother board. Write down the numbers on it and you can find another one at Radio Shack.
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
I can use my Dell OptiPlex GX280 PC Desktop says that windows could not start because drive 1 not found: serial ATA, SATA-2 and drive 3 not found: Parallel ATA, PATA1?
Use your system restore disks to repair your computer since the OS is FUBAR
Without those disks you are SOL. And if you never made them or lost them, now you have learned first hand why it is so important to have them.
Go to the dell site and see if they have your original OS in an iso file for installation. If so that will save your sorry b---.
I have problem with my fan when turn on my computer say fan failure press f1 to continued press f2 setup
You should first check to make sure the fan is working. Just open it up and turn it on and see if the fan is functioning properly. If not then you can just order a replacement fan from Dell.
1helpful
Dell Optiplex GX280 restarts suddenly? all files closed and . the restart could be after 2,3 minutes of power on. I don't know why its behaving like this?
Hi, sounds like a crash, do you get any report messages after reboot? Try starting in safe mode; press Del button during initial bootup, once in safe mode you can reset to a time before the problem started. Hope this helps, if not come back to me?
Curser froze at user sighn in not able to sighn in
Try shutting the PC down and rebooting in "Safe" mode. In this mode you can re-set your user accounts etc. On Dell press F12 during bootup to access the boot menu.
1helpful
I can't get into BIOS anymore. It just sails right by when I press F2 and starts up Windows. I've tried DEL and F1 but that doesn't work either. The problem started shortly after I updated the BIOS from...
remove the cmos battery from your motherboard and return it again after 5 seconds, that will restart your BIOS, or you look for the BIOS reset pin on your motherboard just consult your manual as guide.
Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
1helpful
CPU Fan Failure on Startup
if you have tried changing the fan then the problem is with the motherboard & motherboard needs to be replaced.
3helpful
3answers
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
2helpful
4answers
Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Grand Canyon Tech
Grand Canyon Tech
