Question about HP Compaq dc5100 PC Desktop
What Graphics card will fit in my Hp DC5700 Intel core2 Duo?
I have an Hp DC5700 Intel Core2 Duo and it has onboard Graphics. My wife like's to play Battlefiled 2 and i need a fairly decent card to run it. What card could i put into my system? If anyone could help me a it's driving me crazy, i live in the uk. Thank's
  • Darren Hirst Apr 18, 2007
    Thanks for the replies.
    The HP DC5700 is a buiness computer not really made for familiy use.
    Ok for surfing the net but not any good for playing the lastest games.
    You can upgrade this pc with a Pci card but you are restricted to the badwith of the Pci bus.
    Agp cards replaced the Pci as a faster alternative for the Pci slot.
    Pci x has replaced the Agp so your better off getting Pcix motherboards as Agp ones wont be made any longer.
    My choice was a Pci graphics card with 256 megs that would enable me to at least play battlfield 2.
    Again thanks for all your help :_)
The HP DC 5700 does not have a PCI express slot; it has two standard PCI slots.
I purchased an Nvidia e-GEFORCE 6200 with 256 MB, VGA, DVI-I and S-video.
I was unable to find a PCI card with more than 256 MB of memory. All the cards that I found with more than 256 MB of memory are either PIC-E or AGP; it looks like the old standard PCI is going the way of the floppy drives.
Posted on Aug 30, 2008
Mug
Posted on Feb 12, 2008
The pci-e expansion on this model only supports add2 cards the other port is only pci-e x1 i think you will need to look for a pci card and not pci-e
Posted on Apr 18, 2007
It's just that the wife loves to play computer games and the onboard wont run the games she has. Thank you for taking the time to check my computer and finding the time to reply. All the best
Posted on Apr 13, 2007
    President:
  • 2,961 Answers
From what i can see about your model you can fit a 256mb or 512mb PCI Express graphics card either nvidia or ATI as long as it's pci express, but the details only show one slot so not much room for more expansion.
  • andrew pester
    andrew pester Apr 14, 2007
    thanx for the rating
SOURCE:
Hi. whenever i play a game that need some force power about 30 mins later the screen will go blank and then go into like a frosn static
this is normally a driver problem or a overheating problem--try updating your graphics drivers first and make sure there is plenty of ventilation around your laptop possible to turn your frame rate down as well.
Nov 09, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
Macbook Pro graphics card replacement
There is no graphics card. Apple laptops integrate te graphics into the logic board. Test with an external monitor to verify that it isn't just your LCD screen.
Nov 10, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    When i play games i get a error "your Nvidia display card has stopped working---" so i have to restart every time my computer config is windows XP pro intel core2 duo cpu@2.93ghz 2gb ram Nvidia...
    actualy there is a problem with nvidia chipset display card it gets overheated if possible remove the the card clean it properly and refix it also check the heat sink on the card is properly fitted this will solve the error problem .
    Nov 25, 2010 | Nvidia GeForce 9500 GT, PCI Express Video...
    Hp compaq cpu two processor do not have the same operating frequency ranges
    can I upgrade to intel core2 quad in a hp compaq dc5700 small form factor
    May 04, 2010 | HP Compaq dc5700 Small Form Factor -...
    Fifa 09 freezing not running fast
    Geforce 7100 is a built in graphics card, so you may not be able to play this game at a high setting. Try lowering the game settings to see a improvement in speed.
    Aug 08, 2009 | Buck FIFA 09 for Xbox 360
    Installing visual basic v5 on HP DC5700 (Win XP)
    HP's software may be interfering with the installation process.  Make sure that all unnecessary software has been shut down, including AV, Antispyware, firewalls, etc. before you start the installation.  Checking the error log for specific info would help determine what is causing it.
    Oct 19, 2007 | HP Compaq Business Desktop dc5700 - Core 2...
    MACHINE GETS REBOOTED WHEN USING HIGH GRAPHICS
    Assuming you are running Vista; you can find out what the problem may be by going to control panel> system & maintanence> administrative tools> event viewer>windows logs. look in all the catagories to see if there are any clues as to your problem, but normally i would say it's a graphics driver error or processor overheating, especially if you have onboard graphics and not a seperate dedicated graphics card.
    Jul 13, 2007 | Intel Motherboard
    HP Compaq dc5100 PC Desktop Logo
    3,403 people viewed this question
    Top HP Computers & Internet Experts
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
