Question about Canon MultiPASS C555 InkJet Printer
Printer installation? I recently had my computer re-programmed. Now I can't print. I suspect that my printer isn't installed properly even though it is connected b/c my computer doesn't recognize it. Any Advice? It is ia Canon Multipass C555. Thank you
  • 741 Answers
You will have to reload your printer. Plug the printer to your computer and reboot. The Plu and Play should recognize it. Then the Ad Hardware Wizard will pop up. Load the CD that came with the printer and the Wizard will allow you to load and configure the printer driver. Once the drivers are loaded you can print a test page. If it is a USB printer then load the drivers first, then plug your printer in and reboot.
Posted on Dec 24, 2008
Sounds as though it's printing but why isn't it actually printing?
I would suspect some residue from the stuck cartridge is clogging the new one
Nov 05, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Everytime i print anything ..this message comes ( this document failed to print ) even though it prints the test page
"this happens where there would be a problem in the installation of the printer program..I may suggest to try to restart first the computer and the printer..then if that did not work try to uninstall the printer program and re-install it again.."
Jul 03, 2011 | Computers & Internet
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
How do I print With Windows XP? When I try to print the computer goes to xps and says create a file,but even though I create the file I still can't get that file to print
This only shows that the printer is not installed properly. Most printers comes with an installer or driver, be sure to install it properly and check the wire to see if it's connected properly.
Insert the CD in to your drive, then just follow the steps. After this, you can now see your printer in your options when you try to print.
Oct 25, 2010 | Computers & Internet
Priter does't respond when i used it to print a document
Printer isn’t responding? Please check the following:
i. Is it powered on? If so good.
ii. Is the printer cable connected from printer to your computer? If so good.
iii. Check to see if printer is properly installed. Go to start/control panel/printers and faxes. When the box pops up with the list of installed printers check to see if your printer is listed. If not listed it means your printer is not installed. This also invariably implies that your printer cable (from printer to computer) is bad. Change it and your printer should install and you should be able to print then.
Dec 04, 2009 | HP DeskJet 3550 InkJet Printer
New Epson TX101 cannot print from network
'why i cannot cannot connect printer my network have some alitle bit computer that cannot connect and other can. I already check Computer Name, IP and WORKGROUP. but when i ping to computer that has printer it work. How should i do about this or this printer share only alittle.
May 13, 2009 | Epson Computers & Internet
My printer is intalled but it does print.
Your problem is that even though you say that your printer is installed it stll isn"t and you need to reinstall your printer driver softaware and be cautious to answer all the questions correctly.
Dec 26, 2008 | HP LaserJet 2840 Printer
Even though printer cartridge was recently refilled, documents are not being printed properly.
I suspected a possible cartridge filter damage, so the cartridge was replaced. I am pleased to report that documents are being printed without a hitch.
Aug 14, 2008 | HP Office Equipment & Supplies
Canon MultiPASS C555 InkJet Printer Logo
old marine
old marine
