Question about Motorola Mobility RAZR V3i Cellular Phone
Display screen not working
When I turn my phone on my display screen does not turn on.
    Brigadier General:
  • 7,752 Answers
The lcd needs to be replaced
Posted on Dec 28, 2008
Samsung Anycall screen won't light up
hi i have a problem on samsung shw m110s ..i cannot see any display but its working ..what shoul i do?
pls help
Jul 10, 2012 | Cell Phones
My Samsung GT-E2120 phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only...
My Samsung GT-E2120i phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery.what do I do to solve this?
Oct 27, 2010 | Samsung Eternity Cell Phone
Lg phone screen cracked but when you look it closely it doesn't have crack lines. crack lines only appears when it is turned on and not present when the phone is turned off why am i suppose to do?
The glass of the lcd screen is not cracked, but internally the display is'nt working perfect, few lines are not displayed on the screen which makes us to assume that the screen is cracked which is not the case, you need to replace the display, it its one or two lines you can use the same display screen, their won't be any damage to your phone due to non display of few lines.
Jul 29, 2010 | LG Televison & Video
My phones screen goes white
WHITS SCREEN DISPLAY.
hi,
there are two kinds of white screen in n70 ,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your N70 im sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to a nokia care center to fix you problem...
i hope ,i will help you ,thanks for trusting fixya...
Jun 17, 2010 | Kyocera wild card Cellular Phone
Razor v3 phone screen
is it a blank screen, if it is, the problem with your phone is that the flex on the screen of your phone is weak or damage, that is why your screen did not display.
All you need to do is to replace the flex on the screen of your phone and you will see that your phone screen will display. Change the flex on the screen of your phone as advice and you will see that your phone screen will display.
Take care.
Jun 06, 2010 | Motorola Mobility RAZR V3
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
Phone is on screen will not come on but buttons light up
i think the is a problem with the strip. It connects the board and the display screen. It may be damaged. Change the display and check if it works, if it does not work then the prob is with the strip else it will be with the display. Please let me know if you have any queries.
Regards, Kesav
Mar 02, 2010 | LG Neon GT365 Cell Phone
Phone sceen turns on. fully charged. touch screen works. Phone doesn't turn on. Phone off displays after I have touched the on/off switch.
With the phone screen showing, press the red button at the right-hand side and hold it for about two seconds. The Centro should display a "Welcome" screen, then after a few seconds the phone screen should reappear with the carrier name at the upper left instead of "Phone Off". Each time you press and hold the red button the phone switch on/off..
Oct 26, 2009 | Palm Treo 500 Centro
Main screen not desplaying when I open up my Nokia 6131
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Apr 28, 2008 | Nokia 6131 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
