Question about Char-Broil Deluxe Charcoal H2O Smoker
For got how to setup and smoke
Lost manual how to set up and cook.
    Problem Solver:
  • 9 Answers
Http://bbq.about.com/od/barbecuehelp/f/f060604a.htm This about the best instructions I can find, better than I could explain it myself....good luck.
Posted on Aug 10, 2009
Need instructions
Posted on Jul 26, 2009
Why does my. MAgic Che f microwave smoke inside when I cook bacon?
Although bacon can be cooked in a microwave, cooking any low water content food is ******* an oven, and can shorten the lifespan of the magnetron.
The smoke you're seeing is probably from the grease in the bacon. However, there's a slight chance it's from the power transformer as these sometimes fail slowly. You should be able to tell from the type of odor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 11, 2017 | Microwave Ovens
I have lost my manual for my Cook'n Ca'jun Smoker and need instructions. Thank you.
Here's a link to your missing Owner's Manual. You can download and print it for future reference.
http://images.brinkmann.net/docs/pdf/810-5301-C.pdf
Hope this helps. Thanks for choosing FixYa.
Aug 27, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
My smoke detector periodically goes off when I am cooking although no smoke is detected.
You most likely have an ionization type detector which detects ionized particles of combustion. This type of detector does not look for smoke density but for ionized (excited) molecules in the air. Water vapor from cooking can and will set off an alarm. Burning a piece of toast in the toaster with little or no smoke will also cause a false alarm. Try moving the smoke detector further away from where you cook. This will most likely solve your problem. Hope this helps.
Jun 26, 2010 | GE Security Simon 3 Wireless Home Security...
Replaced battery still beebing
Still beeping,brand new battery?Hook near a kitten?Cooking might set it off.Cooking or smoking set it off all the time.
Jan 16, 2010 | First Alert SA302 Dual System Smoke...
I HAVE LOST MY MANUAL FOR THE GRILL/SMOKER AND NEED TO KNOW HOW LONG TO SMOKE A TWENTY LB TURKEY
To successfully smoke a turkey, use this formula: 30 minutes per pound at about 230 degrees Fahrenheit. That means it will take about 10 hours to smoke a turkey at 230 degrees Fahrenheit. After about 9 1/2 hours, stick a meat thermometer deep into each side of the breast making sure not to hit the bone and let it sit for about 30-40 seconds. The temperature needs to be 165 degrees Fahrenheit to be properly cooked and not make anyone sick.
Dec 17, 2009 | Meco 5030 Smoker
Lost Manual - not sure which is high or low
Hi. I'm a Ronson Service Centre.
I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Mar 15, 2009 | Crock Pots & Slow Cookers
My Brinkmann Electric Smoke and Grill (Double) is cooking
I hope your turkey turned out OK. I read all of the smoking and grilling forums and it seemed to be a very common occurrence yesterday that turkeys cooked in far less time that the grill masters thought they would. Could be that most birds are pre-brined and the additional moisture causes the birds to cook faster. Could be that they are leaner than in the past and the fat renders sooner, causing internal temp to rise faster.
I would let it cook and just check the internal meat temperature at regular intervals starting about 15 minutes per pound.
At what temperature was your smoker running during your cook?
Pat
Nov 27, 2008 | Brinkmann Smoke' n Grill Electric Double...
Cooking time
Here is a link to the manufacturer for replacement parts for the 4-quart cooker:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=802&secid=54&linkon=category&linkid=101
You can download the instructions from this page.
Sep 18, 2008 | West Bend 84754 4-Quart
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Help! Trying to speedbake my turkey!! Lost instructions!
you are better off cooking normally unless you want a dried out turkey. besides cook times vary with every range get to know your stove
Nov 22, 2007 | Frigidaire FEF366 Electric Kitchen Range
Char-Broil Deluxe Charcoal H2O Smoker Logo
779 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
