Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
To anyone that can help, After a year in Iraq, my casio triple sensor pathfinder watch quit working properly. None of the "outdoor" Altimeter, barometer, compass, backlight features work and the word "Recovery" keeps poping up. The time and date do still work. Thank you for your assistance.
  • 1 more comment
  • Mike
    Mike Feb 19, 2008
    My Casio Pro-trek PRG-60T has stopped working, time and date still work but none of the buttons activate ant of the features, i have had this watch for about 3 years now.
  • Anonymous Nov 28, 2008
    i need instruction manual for casio triple sensor ATC-11OO
  • Anonymous Mar 31, 2014
    after a couple days of darkness the watch re set to jan 1st and will not respond to me tryoing to set it
Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
Posted on Mar 01, 2009
  • 374 Answers
Try recharging the battery. Recovery usually comes up when the watch is trying to converse power. Tape it to the inside of a window for a couple of days and see if it goes to full power again. If not then you will have to send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
    Problem Solver:
  • 5 Answers
What is the battery charge indicator showing? If it shows L (Low) then that is why all the non timekeeping features have stopped working.
Try charging it in bright sunshine for several hours over two or three days and it should return to High when all those functions will work again. Check out the instructions on recharge times for a run down battery in this watch unit at http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2767.pdf
Posted on Feb 19, 2009
Had same problem. Solution was to replace the battery. (Yes, it supposedly should never need to be replaced, however if it gets drained for too long, it can permanently be damaged).
Posted on Sep 10, 2008
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
I need the instruction manual
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Feb 09, 2011 | Casio Triple Sensor Pathfinder PRG60T-7AV...
How to set the analog time
If you haven't got instructions on how to do this, you can get
watches;
Accept terms
Read the number of the back of your watch and enter it into the search box
Apr 07, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
LIGHT CASIO PROTREK PRG60 TRIPLE SENSOR
Enter Altimeter Mode
Press and hold Adjust Button
Now press Baro Button
(It will off Auto Light Function)
Oct 25, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Pathfinder watch ??
that old of a watch would need to be sent in. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Mar 07, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Pathfinder 2273 Reassembly Help
Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
Nov 18, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
702 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
