Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Hi, switch underneath our miele g646sc washing machine burnt out. It is situated in a round case, with a polystyrene disc above it. The whole of this plastic case, abour 3" dianeter is clipped under the main body of the machine. Do you know what this one does so that we can try and rectify any problem that has caused the burnout, and any idea of part number or where we can see an exploded part drawing? Thanks! Steve
  • 14 Answers
It is usualy caused by dampness from water in the waterproof tray. the switch is for flood protection.a miele service agent would be your best bet
Posted on Aug 26, 2009
I have a Miele W 2389. Message saying waterproof system has activated. Turn off stop ****. What does it mean?
Hi Dear. Seems like your machine had internal leak. Float switch has been activated. That triggers error message on the display. What you can do is: Tilt the machine 45 degree (Back or forward which ever easy for you) wait for leaked water come out underneath the machine. If water comes out of machine, it's a indication of one of the plastic component failed(it could be drain hose- tub to pin trap hose- may be inlet valve etc....) If there is no water coming out of machine, float switch may be malfunctioning. In that cases you need to contact Miele center to get help.Thanks.
Apr 17, 2016 | Miele Washing Machines
On and off switch has Been pushed in slightly but still works Miele W3623 wash machine. Is it possible buy a new switch
replace the whole display panel or can buy the switch
Tony, It looks like Miele wants whole panel replaced on the washer.
Miele Customer Support Product Manuals Brochures
Mar 31, 2016 | Miele Washing Machines
What to do about a washing machine, that does not heat anymore?
It could be the contacts of a switch (or the electronic part) is defect, or the heating. Mechanics are not cheap, so to invite one for the repair could cost between 200 an 600 euro or dollar. depending what the parts will cost. if the machine is about 10 years of age I would think twice before I invite someone for a repair, because even with a new heater, the rest of the machine is not that young. I would replace the whole machine. Miele should work for 20 years, but Google and see in how many fora they are talking about defects.
Success
Jul 25, 2014 | Miele Washing Machines
All lights flashing
Try powering off the machine using the main power switch for at least 10 seconds, then power back after holding down the top solo and start/stop simultaneously.
You may need to check the drainage pipe and water inlet for blockages. Under the filter inside, you can remove part of the drainage system by removing the silver clip and pulling on the plastic segment.
Wash this through, it has a lovely ball bearing inside, but don spend too long wondering how big it is. Big it is.
Check the tubes, for kinks etc... Always disconnect the water supply before detaching the inlet, and be prepared for a mess, if you do decide to remove the drainage outlet pipe.
Failing this, the following post may help:
Check out this solution to the Miele 24 in G646SC Plus Free Standing...
Feb 18, 2014 | Miele 24 in. G646SC Plus Free-Standing...
Miele washing machine w534 fills with water then immediately pumps out. Any ideas thanks
the problem of your unit is the main pcb board if electronic type or the mechanical switch problem, but same cause its burnt part and its hard to check. call the technician for your safety and to not waste your money to buy some part if you dont know what the main reason why its burnt part..
Oct 31, 2013 | Miele Washing Machines
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Drain pump runs continuously
Which model do you have and is there any fault codes showing on unit? I have all of the service manuels for miele products.I am factory auth. for service on miele.
Feb 22, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
198 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
