Question about Rio CE2100 MP3 Player
Need battery The battery, after prox 2 years, is not holding a charge like it used to. Does anyone know if there is a replacement battery for it? If so, where can it be gotten. Also, are there instructions to replace the battery? Thanks George
Sorry dude. but i found out that u can change the battery. its a lithium-ion battery. and the sucky thing is that i is non removable.
sorry!
Posted on Dec 28, 2007
  • Jessica Dec 28, 2007
    sorry dude. but i found out that u cant change the battery. its a lithium-ion battery. and the sucky thing is that it is non removable.
    sorry!
Nokia lumia 800 won't hold charge
First you would need to check the connectors on the charge cable and if its still not charging, then do a hard reset which means totally power the device down and then power it up and then try and charge again. Your charging cable might be defective. You can remove the battery go to bottom of device, remove memory card, then use a small screwdriver. But I would first try the first two steps because removing the battery on this device would require you to dissemble the whole device
Jul 28, 2013 | Cell Phones
I bought the glowbouy last year. I replaced a bulb, charged it up and now it doesnt work. The light switches on for a split second when i go o switch it from off to light. The light goes on briefly then...
It sounds like your swimming pool light is not holding a charge. This normally indicates that the batteries have expired their useful life and need to be changed. Even rechargeable batteries are not designed for permanent use.
Jul 06, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Ultimate Wall-E robot won't hold a charge
I found this battery and it works with my Ultimate Wall-e, even charged with the charger that came with Wall-e:
http://www.lynxmotion.com/p-67-72-volt-ni-mh-1600mah-battery-pack.aspx
Feb 10, 2010 | Thinkway Toys
Had mine for 4 years now. Worked fine since. I have found if I don't use it for a while (2+weeks) the battery goes completely flat. When I go to charge it, it doesn't power up and charge; instead, when I...
Probably your phone battery is already condemned since it has given its best service in 4 years now.. Go to nearest outlet and get the battery replaced to avoid something dangerous.. Several people died in cases of condemned battery dysfunction. Feel free to care for your health and get your phone's battery replaced.
Jan 03, 2010 | iRiver H320 MP3 Player
CM1000 quality cordless mower?
I have owned a cm1000 for about 10 years and have been very pleased with it. I received a replacement charging circuit board as a recall item but other than that no problems. I can usually mow my front and back yards about twice on a charge. I think I will replace the batteries this year for the first time because they are not performing well.
Jul 05, 2009 | Black & Decker 19" Electric Lawnhog...
Battery
It is possible the battery could need replacing. Most rechargeable batteries will lose their ability to hold a charge if not used. "If you don't use it, you will lose it." If this is a 1 or 2 gb player, it may not be worth fixing unless you are really good with electronic repair and able to replace the battery yourself.
Nov 03, 2017 | Sharper Image PD210 MP3 Player
Nokia 2285 is turning on/off by itself
It's a software issue. Take to a nokia care or repair centre for full flashing using a computer system.
Apr 23, 2017 | Nokia 2285
Dvd player does not hold a charge ( has a new battery )
take a voltmeter and test charger or borrow a known good one from a friend if you know anyone who has one , sounds like bad charger word--- it is much better to run all rechargeable devices mostly all the way down before recharging as these batteries will do what is know as establish memory and will shorten battery life do not leave on charge except when charge is needed
Nov 18, 2008 | Polaroid FLM-3732 Television
Manual
Mine won't hold a charge either. I've had it for about a year and used it about 6 times. I have the manual and it is no help. I guess the battery is bad after a year. What a bummer. Don't purchase this product.
Jul 13, 2008 | Campbell Hausfeld Cordless...
Samsung YP-T7 Battery Replacement
I have the same problem. I loved this player... worked great, i used it all the time and only had to charge it every 2 weeks.. then suddenly out of the blue it won't hold a charge at all. Anyone found a way to buy a new battery??
Dec 05, 2007 | Samsung Yepp YP-T7JX MP3 Player
Open Questions:
Rio CE2100 MP3 Player Logo
137 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
