Question about Brother SE-270D Computerized Sewing Machine
Brother SE-270D balance wheel is very hard to turn manually
The machine made a whinning noise then the motor started skipping on the belt and the machine's computer gave an error.  the balance wheel can be turned manually but it is very difficult as though something is caught up in the machine.  i opened up the machine and cleaned out the lint but i cannot see where the resistance is coming from.  the only thing i can think is that somehow a length of thread may have wrapped itself around the mechanical crank/cam where i can't see it and is preventing it from turning easily.  am i on the right track or is there another known issue i am overseeing?
  • Brother Master
  • 667 Answers
This is the first and foremost problems that I've found: The bobbin case is packed full of threads. The needle is crooked and must be replaced.
1. The bobbin case has a hook that turns to catch the top thread when the needle is down. The bobbin case assembly must be removed and cleaned totally. The bobbin case assembly is where the bobbin sits. The bobbin case has a black bar that sits on top of it. Listen the forward screw and slide the bar slightly. You will need to move the hand wheel to move the hook to the front-most position. When you have done this the bobbin case will come out easily. Clean it thoroughly and put one drop of oil on the track. This is a lower spot where the bobbin case sits on top of. Before you put the bobbin back in you need to check the tension. It is intended to be even with the top tension.
2. Replace needle and make sure it is in totally and is seated the right direction.
HOPE THIS HELPS
Posted on Apr 16, 2017
dupina
  • 110 Answers
SOURCE: Brother SE-270D - need timing instructions
If your machine bunch up the tread, it has nothing to do with timing. In 90% of the cases the problem lies with the top thread. Check your tension disks for any fluff or thread. Also check that you thread the machine correctly. The best way to check the tension is to thread the machine normally with the presser foot up. when you get to the stage of the threading the needle, first lower the presser the presser foot and check the tension by pulling the thread slowly with your right hand and adjust the tension with your left hand. On zero you should be able to pull freely and on 5 there should be enough resistance. If this is the case your machine should sew perfectly.
Hope this help
Posted on Jan 18, 2008
  • 29 Answers
SOURCE: Brother SE-270D Jams below needle plate
Comment by margecam52, posted on Aug 12, 2008 It's the bobbin thread. Also, it does not have to be Brother brand. Any 60wt thread will work. I get mine at http://www.threadart.com
They have it on large cones, and I use a cone holder to fill my bobbins. I have not had a single problem since. I like this thread because it has a sheen to it. I also have a longarm quilting machine & I use this bobbin thread 95% of the time. Also, be sure to check the bobbin area (remove the plastic & the metal plates) for lint buildup... I have a small, soft artists paint brush that I use to remove the lint build up with. I check after every embroidery run.
And for the thread not coming through...mine does it when I change thickness of threads. There is an adjustment wheel on the front of the machine, I turn that...seems to make the difference...not even sure that is what it's for...but it works for me.
Posted on Aug 12, 2008
SOURCE: "Lower presser foot" error on SE 270D
OK; My SE-270D is about 5 years old and it just recently started giving me the "lower presser foot lever" I have already spent $30 going on line to fixit websites only to be told to take the unit to a service center. I went through the normal routine of trying to reset the computer of which did not work. I can't afford to spend $75 just to let someone look at my unit and then pay even more to have it fixed. I could buy the same machine or equivalent (brand new) for about $200. I am sort of mechanically inclined so I decided what the heck, I will just open up this machine and try to figure it out myself. I mean what do I have to loose. I opened up the unit and discovered there is a tiny "pressure switch" which is activated when the lever is pushed up or down. When the lever is up the switch is "off" when the lever is lowered it releases the spring loaded whitch to the "on" position. The tiny switch is right below the thread tension dial. I discovered that the switch could be activated manually by pulling it over with my finger. I had to make a hole in the casing so I could get to the switch after I put it back together. WALA! it works. When I lower the presser foot lever I then pull the broken switch into the proper position and it works like a sewing machine. I gambled on this solution because I have a tiny bit of mechanical knowledge. So if you are lacking in that area, please don't try it.
Posted on Nov 26, 2008
  • 37 Answers
SOURCE: i have a brother se-270d sewing machine. the
sounds like the bobbin tension is too loose. Try tightening it up a tad
Posted on Jun 05, 2009
  • 52 Answers
SOURCE: Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Posted on Jul 16, 2009
I have a JUKI DDL-8700N. I recently moved the machine and the movers turned the machine on its side. Now the sewing speed is very fast and it doesn't stop when I take my foot off the pedal.
Carmen, Your belt is either twisted or is not down in the groove in the hand wheel or in the pulley that is on the end of your motor. Use a flashlight to look at the end of your motor (under your table). That is a common problem. Once you think it is probably on both the hand wheel and the pulley, start turning the hand wheel towards you about 10 times. Sometimes that helps it settle in. When this happens, the hinges sometimes get crooked and you will need to try to straighten them by jiggling the head of the sewing machine until it settles in. Good luck.
Dec 07, 2016 | Juki DDL-8700
Makes a whinning sound. Does it need oil & if so where to put it?
The whinning noise could be a slipping belt which you need to check, you should be able to take the side off to see
Sep 12, 2011 | Necchi 6015 Mechanical Sewing Machine
I have singer 2404 and it has been sittind for awhile i clean it up oilled it and when i try to start it the wheel wants to go round but i just hear it rumble if i turn the wheel it goes but if...
Either the belt needs adjusting or you are starting to sew with the takeup lever at the top which will hold the machine back, if you have a horrible rumbling noise near the balance wheel the chances are the topshaft needs oiling
Aug 10, 2011 | White Sewing Sewing Machines
I have a Brother Se 270D sewing/embroidery machine. It makes a terrible grinding sound and won't go all the way up or down. I have removed the thread, bobbin, and bobbin case and cleaned all of...
Take it in for service, hopefully it is still under warranty, I have sneaking suspician that your motor is causing the problem. I had a machine that did that and it turned out to be the motor.
Apr 20, 2011 | Brother SE-270D Computerized Sewing...
F01 trouble code when turning on my brother SE270D sewing machine
Do you have your manual? If, not just google brother.com and download one for free, also you can call Brother at 1-877-276-8437. Good luck
Jul 19, 2010 | Brother SE-270D Computerized Sewing...
Error code 6 (thread in motor but there is none)
If you can turn the balance wheel by hand and the needle goes up and down it may be loose belts, if you can't turn the balance wheel by hand then there is definitely thread stuck somewhere in the raceway
Jun 24, 2010 | Brother CS6000i Computerized Sewing...
The hand wheel keeps falling off and now when i try the sew nothing happens, the needle does not move. all i hear is the sound ofthe motor but nothing happens
If the balance wheel is coming off which it should not do because it is held on by the belt then you have not tightened the stop motion in the middle of the balance wheel, make sure you have not lost the little screw in the middle if the balance wheel.
Feb 15, 2010 | Sewing Machines
I have a Brother SE-270D. The top thread is not
A bent needle will cause this. Otherwise the shuttle is out of time, have it serviced..
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
55 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
