Question about GE (PSS26MSRSS) Side by Side Refrigerator
Humming My fridge started to make a loud humming noice. it can be heard all over the house. it did not always do it. it is about 4 years old
  • yhkcbay Dec 27, 2008
    Mine howls, moans, whines...believe it to be the "efficient" compressor by ge's wonderful six sigma engineers. I'm going to shoot mine at some point in the near future.
  • 115 Answers
The main board needs to be replaced on the back of the refrigerator it is making the voltage drop
Posted on Dec 30, 2008
Humming noise in house
Might be a noisy draft inducer motor. Try backing out the bolts and repositioning it is what I would try. Or pay a dude $400 for a new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 30, 2013 | Dryers
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
126 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
