Card reader stopped working
The card reader in my pavillion elite m9260f has stopped working. the card reader drives no longer show in my computer.
  • Anonymous Mar 28, 2009
    when i copy the file to card reader after copying some files it will stop then again plgging the card reader in usb than same problem again
  • Anonymous Mar 12, 2014
    card reader drive cannot be seen on my computer
    Genius:
  • 1,066 Answers
Go to the pavillion website and download drivers for the card reader (you can find the correct drivers by searching the model or serial number to your machine). install the drivers for the card reader (they prolly dont take drivers, but try anyway) the card reader is most likely defective, or the ide ribbon cable came loose from the back of it.
Posted on Dec 24, 2008
My computers (HP Pavillion dv9608ca) laptops sound has stopped working and no longer shows a sound card in the sound settings, how can I fix this?
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
Jan 26, 2011 | HP Computers & Internet
My HP Pavillion 3112sa Card Reader has stopped
You need to install the card reader drivers.
Contact HP they will quickly provide you with the drivers.
If you would have mentioned the operating system then I would have searched and provided you wit the drivers.
Note: Operating system examples are vista, xp.
Jun 18, 2010 | HP Pavilion dv6000z Notebook
Sd don't work
Hi:
Does your SD card reader show up as a drive when you go to : "My Computer" ? if it does, insert your SD card again, and see if the pictures are veiwable when you double click on the drive icon.
If the drive is not showing up in the my computer page, the driver might not be installed or the actual drive might be dirty or defective. You can check this by going to "control panel" , "system", and then "device manager." The SD card device should show up without any yellow exclamation points by it. If any devices have exclaimation points by them, you need to research what they are and find the proper driver for them to work.
Feb 10, 2010 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
COMPUTER WONT TURN OFF
You need to tell HP about your problem. www.hp.com/support ... look for e-mail help or chat help for your answer. There MAY be a problem with the line.
I hope this helps
Oct 17, 2009 | HP Pavilion Elite m9260f Desktop PC
How to format corupted microsd
Before you start, please make sure you have a reader that can read and write to 2GB card properly. DO NOT use in built-in reader on laptop and desktop, or old readers made 2 years or longer ago, because these readers can only use up to 1GB card. I recommend using it in external USB 2.0 reader that is made within 1 year ago.
If you do not have such reader, then connect the device (gps/camera/pda/camcorder) to the computer with USB cable and the card inserted and if works you should see new drive letters show up under My Computer.
Otherwise, if used in devices that do not support the 2GB card, the card will be damaged.
Please try the following troubleshooting guide first and see if it can solve the problem. Try one step at a time. If one works, then you can stop trying. You don't need to try all of them.
The following guide will erase all the data on the drive/card. So make sure you backup your data first before you try the steps below:
1. First, remove the card/drive from your computer.
Download the low level format tool below to your computer.
http://hddguru.com/download/software....2.36.1181.exe
Install the program into your computer.
You should see a new icon called "Hard Disk Low Level Format Tool".
a. Insert the card/drive and run the program.
IMPORTANT!!! MAKE SURE YOU SELECT THE CORRECT DISK OR YOUR COMPUTER MAY NOT START LATER!!!
It should shows as BUS: USB. Select the BUS: USB. Also check the size and make sure.
If you don't see BUS: USB, that means the card is unreadable and need to be replaced. In this case, please STOP here and close the program and DO NOT continue below.
b. Then click Continue->Low Level Format->Format this Device.
c. Wait for a few minutes until it finish successfully with a message of asking you to partition and format it. (if you see formatting error, you can stop the formatting and the card needs to be replaced.)
d. Flash Card:
Put the card back into your device and then use the format utility in the device to format the card.
Sep 03, 2009 | Garmin eTrex Venture Cx GPS Receiver
Tower will not boot or communicate with monitor
Don't throw out that computer or replace any components just yet.
After much trial-and-error, I finally figured out the solution for this common issue with certain HP Pavillion models. It turns out to be a design flaw with the front-panel memory card reader. Somehow the card reader's firmware gets scrambled, and it prevents the computer from booting. You can test this on your machine by temporarily disconnecting the card reader cable at the motherboard header. Voila - I'll bet you $1 that your computer will now boot!
The solution is buried deep inside this HP tech support document. The card reader firmware needs to be reset.
Here\'s how to fix it once and for all:
1) With the computer power unplugged (duh), open up the case & disconnect the card reader cable at the card reader itself - NOT the end that connects to the motherboard header. Make sure the cable end is not touching any metal components before proceeding to step 2 (another duh).
2) With the cable still disconnected, fire up the computer. The tech support doc says to let it boot into Windows and stay there for about 5 minutes.
3) Shut the computer down and reconnect the cable to the card reader.
4) Turn your computer back on - your memory card reader will work and, most importantly, the computer will no longer hang at POST!
I suspect that when you fire up the computer without the cable connected, the card reader is designed to reset its firmware by grounding out through the case - sort of like a CMOS Reset jumper on a motherboard.
I hope this solution is helpful to others.
best,
JohnB
Mar 29, 2009 | HP GX612AA Pavilion Media Center M8330F...
I have lumix dmc-lz7. Tonight I put a 2 gig sd card into my built in card reader , Dell pc and it didn't work and did not even show the drive on computer. Then, to check it out, I connected camera to usb...
maybe the card reader is not SD/SD HC compatible, the same problem occurs wiith the Memory Stick Pro/Duo of sizes 2GB or above in my Desktop Computer (Compaq) and not in my Notebook (Compaq) the card reader and the machine are newest and are compatible
Jan 30, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Usb card reader is not connected but shows as connected
DISCONNECT THE READER IN THE MY COMPUTER SECTION BY RIGHT CLICKING AND ACCESSING THE PROPERTIES MENU BEFORE U TURN OFF THE COMPUTER
Aug 04, 2008 | Electronics - Others
HP pavillion a800n pc wont' boot up..I get nothing...
best,
JohnB
Oct 31, 2007 | HP Pavilion a800n (PP163AA) PC Desktop
Computers & Internet Logo
420 people viewed this question
Alun Cox
David Payne
David Payne
