Question about AT&T Blackberry Curve 8300 Smartphone
When set to vibrate+tone all I get is vibrate.
When I set a notification profile for the phone to vibrate+tone, all I get is vibrating. For a tone, it must be set to tone only. I need it to vibrate and ring at the same time.
I had the identical problem, and was about to replace my unit. When I popped the SIM card and battery back in, the problem was solved. Basically a hard reset. Don't know whether it made a difference, but I left it out overnight. Hope this works for you.
Posted on Dec 26, 2008
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Have a wonderful day.
Jun 20, 2011 | Nokia E5 Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
I have the ring tone set to vibrate & the phone does not vibrate. this just recently happened. Use to work fine before.
The vibe motor is inside the phone and can be replaced at a service center. Hopefully the unit has no physical or liquid damage.
Mar 24, 2011 | Motorola Mobility RAZR V3
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Can't set my blackberry curve to ring and vibrate at same time
To silence your device
In the profile list, perform one of the following actions:
• To receive LED notification only, click Quiet.
• To receive vibrate notification only, click Vibrate.
• To turn off all notification, including notification profile exceptions and LED notification, click Off.
Hope this helps!
- CBR2009
Aug 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Not Vibrating on Email Receipt Only
Go to profiles, and scroll down to advanced.  Make a new profile and then choose which things you want tone/vibrate/nothing.  Once you name and save your new profile, select it, and youre good to go!
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
How do I get a message arlet tone on a blackberry 8700v smartphone?
Want to change the tone you hear when you get an SMS, MMS, or IM? Want to change the ringer for the phone? Follow these directions to edit the Profiles area on the device:
1. Select the Profiles icon
2. A box will appear where you can quick select between Loud, Vibrate, Quiet, Normal, Phone Only, and Off. If you wish to quick change the device profiles then select the one you want and exit out.
3. If you want to edit the tones assigned to the device applications then select the last option, Advanced
(some older models and OS 4.1 and below will not have the "Advanced" step--if Advanced is not present go directly to Step 4 below).
4. Select the profile you wish to edit. (Loud, Vibrate, Quiet, Normal (default), Phone Only, Off)
Note: on the 8100, 8800, and 8300 models: Do not click the trackball. Instead, click the menu key to the left of the trackball).
Note: The profile that is in use will say: (Active)
5. You will now see a list of all applications that can have a tone assigned (Browser, Calendar, Level 1 Messages, Messages (email@domain.com), Messenger, MMS, Phone, SMS, Task ect..)
6. Select the application you wish to edit the tone / notification for
7. You can now edit Out of Holster and In Holster tones/ notifications.
a) Select between: None, Tone, Vibrate, Vibrate+Tone
b) Select the Tune you wish to use
c) Select Volume (options are Mute, Low, Medium, High, Escalating)
d) Select Number of Beeps (options are 1, 2, 3)
e) Select Repeat Notification (options are None, LED Flashing)
f) If set to Vibrate or Vibrate+Tone then select Number of Vibrations (options are 1, 2, 3)
8. Repeat a-e for each of the desired applications listed in 5 above
Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | Cell Phones
I need help with volume
You may have selected a profile that does not alert you audibly when you receive messages. You may select a different profile, edit the current profile or create a completely new profile. I'm attaching instructions for creating a profile and editing would be similar except you would select a profile then select "edit" for the menu. Be use you have "tone" or "vibrate and tone" selected and that the volume is not on mute. Always save your changes.
Create notification profiles
1.In the profiles list, click the trackwheel.
2.Click New Profile.
3.Type a name for the profile.
4.Click an item.
5.Click Edit.
6.Set how you want to receive notification for that item.
7.Click the trackwheel.
8.Click Save.
9.Click the trackwheel.
10.Click Save.
To turn on tones when pressing the keys, follow the following instructions:
Turn on tones when pressing keys
In the device options, click Screen/Keyboard. Set the Key Tone field to On. Click the trackwheel. Click Save.
Jul 20, 2008 | RIM BlackBerry 7520 Handheld
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
AT&T Blackberry Curve 8300 Smartphone Logo
117 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
