Question about Canon FAXPHONE L170 Plain Paper Laser
Warranty bought fax on 6-19-07 in staples wondering if it is still covered
  • 100 Answers
Note sure. Best thing to do is find a service center or office system dealer in your area authorized in Canon and ask them.
Posted on Jan 10, 2009
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    Acer aspire one 532h purchased on 6/28/2010 from staples. crashed doesnt turn on. i took to staples they said i should have 1 year manufacture waranty. please help. nahidpiloti@yahoo.com. 949-456-7500
    I don't know which country you are in. If in the UK, take it to Staples and they are duty bound to send it away for repair, or at the very least advise you where it must be sent for a warranty repair.
    If it has a software fault, of course, that is not covered under any warranty.
    Feb 03, 2011 | Acer Aspire One PC Notebook
    Have a Electric Stapler B8E E66760. Won't kick out to load staples
    pretty simple. Take off the plastic cover, at the front where it staples will be a black metal piece on top of the stapling area. That is the front clip release. Release the staple tray like you would normally with the button and also Push the top black piece back to detach it from the staple tray. It should spring out then. Clean around it with alcohol and keep the cover off. Push it back in place, release it a few more times to make sure it works correctly now, then put the screws back in.
    Oct 04, 2010 | Office Equipment & Supplies
    Work Center Pro 575 always gets paper jams
    If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
    See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
    Note: The power can be left ON when clearing a paper jam.
    Typical Causes of Document Jams
    Recommended Procedure
    The document is fed at an angle.
    Adjust the Document Guides to the edges of the
    document.
    The document paper is too thin or too thick.
    Make a duplicate using a copier and use the copy
    as the sending document.
    Document has tape or pieces of paper taped to it.
    Remove the tape or make a duplicate using a copier and use the copy as the sending document.
    The Control Panel Cover is not fully closed.
    Close the Control Panel Cover fully.
    The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
    Basic Troubleshooting
    1. Remove all documents from the Document Support.
    2. Open the Control Panel Cover.
    3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
    4. Close the Control Panel Cover.
    5. Verify the display has returned to the Standby Mode.
    Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
    I was wondering if my timing hydraulic adjuster be covered under warranty,i have a 2004 santa fe and it has exactly 60,000 miles i bought it used with an extended warrantythat would equal to 100,000 miles.
    extended warranties have limits call the 800 number or dealer and ask if ur problem is covered they have the list and limitations on your warranty
    Nov 12, 2009 | 2004 Hyundai Santa Fe
    Crack screen
    Your warranty card would have more info, however usually they only cover faulty damage (things that are the manufactures fault.
    To check and find out for sure here is there contact info
    SMC Customer Service: E-mail: support@sanyotv.com
    Phone: (800) 877-5032
    Fax: (870) 630-4223
    7:30 am - 12:00 am Midnight CT Mon-Sun
    Good luck, and sorry for your luck. Thank you for choosing fixya!
    Mar 17, 2009 | Sanyo DP32746 32 in. LCD Television
    Lexmark x7350 Still under warranty does not fax, scan or copy anymore
    Definitely sounds like the scan bar or some related hardware is bad. I would call Lexmark tech support at 1-800-332-4120 and ask them if it is still under warranty and if it's covered by warranty. Hope you registered the product when you first bought it.
    Jul 16, 2008 | Lexmark X7350 All-In-One InkJet Printer
    Flickers and shows acer logo blue screen sever error
    If the warranty will end in 10 days contact your dealer right now or acer. repairs are free if the problem is covered by warranty. (for example not abused)
    let me know if you have any other questions.
    Jun 20, 2008 | Acer AL1716 17" LCD Monitor
    Poor quality fax to fax, copy great, computor fax great.
    beware of generic toner!
    you may need to change out your drum unit
    the drum unit may have been contaminated by the staples toner.
    also clean laser window under drum cartridge.
    Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
    Canon FAXPHONE L170 Plain Paper Laser Logo
    old marine
    old marine
