Question about Vivitar Pink Vivicam 3188 Camera Great kids gift Digital Camera
When i press the on button it just bleeps twice and then nothing
Duno
Probably batteries are low
Posted on Feb 05, 2009
When I choose a cycle on my Bosch logicxx 7 washing machine and press the on button, it just bleeps twice & nothing else happens
Could be error due to door not closed / door interlock fault check at time if door is locked as it should be before machine starts and stays locked for further 3 mins after shutdown.
Jan 01, 2018 | Bosch Washing Machines
Tip
Hi this is exactly my problem but the thing is when i just press the power...
Are you plagued by the problem of your Playstation 3 not booting up properly?
Got a screen with just a background and no icons?
Seeing a wavy line and nothing else?
This is the tip for you!
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
on Jul 23, 2011 | Sony Playstation 3 (PS3) Console
PS3 won't boot up. It starts but will not load menu from the hard drive.
try rebooting hold down power button until it bleep twice and should turn off hold it down again unit it bleeps 3 time then u have secret reboot menu 4 ps3
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
My playstation turns on but nothing happens after that. There is no display or sound output. It will not turn off, gibving two beeps if you try to shut it down. The hard drive light comes on for about...
hello try resetting it turn the ps3 on then press and hold the standby button you should hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset it self
regards
shaun
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
Green light on base of BT Studio 3500 keeps on blinking on and off all the time even when no one is on line. How can I stop it ?
It is indicating that you have missed calls.
If you put the phone in the base cradle and then press the volume button up - keep pressing until you hear a loud bleep - that should solve it.
I had to do it twice but it did stop it.
Andy
Feb 24, 2010 | Lands Phones
When i turn it on it bleeps and f 37 comes on
u have a fault the operation of the washer.
The machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
Jan 12, 2010 | Bosch Logixx WFR 3267 Front Load Washer
When turn on goes green bleeps twice then turns off ps3
The only time that my PS3 does that is when I do a reset of the system. Which means that I am holding the power button when turning on my system. If this is what you are doing, try just pressing the power button once. Or like I do swipe your finger across it like you swipe a credit card.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Sleep mode
Have you tried to unplug it, and leave it out for a few minutes, then repower, this clears the volitile memory.
Ed
Apr 17, 2009 | Brother IntelliFax-2820 Laser Fax
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Vivitar Pink Vivicam 3188 Camera Great kids gift Digital Camera Logo
50 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
