Question about JVC Everio GZ-MG21 Camcorder
Problem with cyberlink power cinema at startup
Every time I turn on my computer, the cyberlink power cinema boots and opens up, and I cannot click on anything that will respond. I cannot close it, or do anything. I have gone into the system configuration and unchecked it from the startup tab, and I even went into the programs and completely uninstalled it, and its still doing it! What can I do to get rid of this beast??
  • Anonymous Jan 16, 2009
    I have the same issue. Just started all of a sudden and is driving me nuts!
  • JVC Master
  • 3,015 Answers
I suggest you download revo.uninstaller. Its a free program which can check what gets left behind after the suppliers uninstall software has done its job.
All too often registry items get left behind creating hooks that allow programs to reinstall etc.
Google Revo free uninstaller
Download the free version to your computer
Select the program you wish to uninstall
Wait while the initial analysis and restore point is made
Select advanced
Select Yes to continue
Select No for personal settings if asked
Click finish when suppliers uninstall is complete
Do not restart computer if asked or you will miss the Revo scan
Click scan to see what registry items are left
Select all and delete
See if any files remain if so select all and delete
Posted on Sep 02, 2017
2 Suggested Answers
  • 13 Answers
SOURCE: Cyberlink POWER CINEMA NE
There are JVC software updates and camera checking software...These can be found only at an authorized JVC service. Anyway, did you drop it?
Posted on Sep 15, 2007
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
Tip
How to Make Windows XP Startup Faster Steps 1.Click on Start, then Run, and type...
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.
on Feb 25, 2011 | Computers & Internet
Slow opening of websites
Steps
Hibernation
Prefetch
Tips
Warnings
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.Remove all toolbar from add or remove program. From control panel. Reset web settings from internet option.
Apr 14, 2012 | Microsoft Windows XP Home Edition English...
Too slow,how can i speed it up
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 09, 2012 | Computers & Internet
My laptop is running slow
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 05, 2012 | Lenovo Computers & Internet
When ever i log on i keep getting a pop up tvagent.exe entry point not found
TVAgent is software made by Cyberlink that comes installed on many HP computers. It is on there so that you can use your computer as a TV. It sounds like its trying to start some type of program or service when your computer boots. It may be looking for the powrprof.dll file which may not be there or be the wrong version. If you don't use your computer as a TV then I would see if you can uninstall the Cyberlink software from Programs and Features.
Or you can also uncheck that particular item from msconfig window.
1) Click on Start >> type msconfig on the search or run field and press Enter.
  1. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
  2. Click the Startup tab, and then uncheck the box for TVAgent or cyberlink application. Click on Ok and Apply. Then restart the notebook.
Jul 25, 2010 | HP Pavilion dv6000z Notebook
I want to disable or uninstall the cyberlink power cinema...uninstall doesn't work...I am tired of it starting up everytime I wipe down the computer
Hello... Buddy! I have a suggestion for you that you reinstall the cyberlink power cinema software using the same disk. When the installation starts, this will ask for repair/reinstall or romove options. choose remove option and take step forwand and if it fails to remove, re-run the setup file and choose to repair/reinstall, when it is done successfully, you may then uninstall it from add/remove programs in controls panel. or program & features option for vista/windows 7. or uninstall it from program menu.
Nov 28, 2009 | Computers & Internet
A message pops up saying ''Cyberlink has stopped functioning''
Try updating your video drivers and see if that solves the problem.
Aug 28, 2009 | CyberLink Computers & Internet
Will not turn on, last time used, I turned it off manually?
Try this:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | HP Pavilion DV6500T Notebook
Startup issue
Sounds like a problem in the power supply section that will need component-level electronic troubleshooting. If it's under warranty and less than 30-60 days, I would suggest an exchange. If not, I would call the number in the manual for help.
Jan 01, 2007 | Apple Cinema HD 30" LCD Monitor
JVC Everio GZ-MG21 Camcorder Logo
774 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
