Question about Canon LaserClass 2050 Plain Paper Fax
Canon 2050P ##323 Error
I am getting a ##323 error when I power up my Canon 2050P fax. Any ideas? I have replaced the laser/scanner and the scnt pcb.
    Scholar:
  • 75 Answers
That is a heater error. the fuser asm. that melts your toner on to your paper. it is not coming up to temp. in time.
sorry to say the only way is to replase it. if you go on the internet googal canon 2050p fuser you can order one
C.W.H.
Posted on Jan 23, 2009
How to solve Error Code: E100 0000 of canon LBP3150
Dear its indicate Laser/Scanner unit failure.
check
1) Turn the power off and on.
2) Make sure that the Laser/Scanner unit and DCNT board are
properly connected.
3) Make sure that the Laser/Scanner unit and DCNT board are
properly connected.
4) Make sure connections of the boards (power supply board
DCNT board and SCNT board
Replace the Laser/Scanner unit.
Thanks.
Dec 28, 2014 | Canon Office Equipment & Supplies
324 ERROR ON CANNON 2050P
That is a laser scanner code. Sometimes the power supply will also throw this error. The power supply is located under the long plastic cover in the back and is easily replaced. The cost for a laser unit is quite pricey and not really worth it. A new fax can be purchased for about the same coin.
Dec 14, 2011 | Canon LaserClass 2050 Plain Paper Fax
Keep getting error A6
Error Code(Hex) : A6
Symptom: FAX scanning failure. (retry)
Probable Cause:- CIS defective White-level reference
film stained in the scanner cover,- Main PCB defective
Solution:- Replace the scanner cover(scanner unit),-
Replace the main PCB.
Hope it helps..
Oct 29, 2010 | Brother IntelliFAX 4100 Laser Fax
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for paper....is it displaying an error code?
Aug 03, 2009 | Canon LaserClass 2050 Plain Paper Fax
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon L220 Fax ##323 Check Printer
Canon manual says ##323 is the laser beam detector defective. Try to substitute the laser assembly (RG5-3497)
Dec 22, 2008 | Canon L220 Plain Paper Laser Fax
Keep saying check printer
5.5.3.3 ##324 [Rx] Printer section scanner motor rotation rate abnormal 0003-5251
Cause
An internal mechanism is faulty.
Remedy
1) Check the connection between the laser scanner unit (J802) and SCNT board (J6).
2) Replace the laser scanner unit.
3) Replace the SCNT board.
Jun 05, 2008 | Canon L220 Plain Paper Laser Fax
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Canon LaserClass 2050 Plain Paper Fax Logo
383 people viewed this question
Clive
Clive
old marine
old marine
