Question about HP Pavilion dv4170us Notebook
Touch pad scroll bar and MS Office shortcut
Recently the touch pad scroll bar stopped working. I've probably disabled this feature without realizing it. I've tried searching the documentation, but can't get it fixed. Any help will be much appreciated. A second minor problem has to do with the MS Office toolbar shortcut. Again, until recently, it remined pinned to the top of my desktop which is very convenient for switching between programs. Now, however, when I pin the shortcut to the desktop, it only remains until I turn the computer off. I then must re do the shortcut the next time I start the computer. How can I make it stay on the desktop? Thanks for your help.
  • jack roberts Apr 16, 2007
    Thanks for the quick reply. The fix you suggested for the MS Office toolbar shortcut took care of the problem.
    The proposed solution for the more significant issue, the touchpad scroll bar problem, didn't work for some reason. When I opened the Mice and Other Pointing Devices item in Device Manager, the touchpad scroll bar was not shown. Only the mouse was there. I've been trying to find the touchpad in the System folder, etc., but have had no luck so far. Any other suggestions?
    Thanks.
  • Anonymous Mar 22, 2014
    Not all shortcuts just some
    President:
  • 2,961 Answers
Firstly the touch pad, right click on my computer>properties>hardware tab>device manager, then look down the hardware list for mice and other pionting devices and click on the '+' sign, there you should see your touchpad. Rght click on it then click uninstall, restart your notebook and the driver will re install the touchpad at default settings. Secondly shortcut problem, click start>run, then type 'msconfig' and press enter. In the next window click the startup tab and look for anything Office tool bar related and ensure it is ticked. Click ok then a box will ask you to restart, do s,o then another box will pop up after your desktop has loaded saying you have made changes, just tick 'Dont show this again'.
Posted on Apr 13, 2007
  • andrew pester
    andrew pester Apr 17, 2007
    The touchpad should be listed somewhere, there may be an 'Other Devices' in the list with an exclamation mark, and theres no driver listed, download this programme to run support on your pc
    http://h10025.www1.hp.com/ewfrf/wc/softw...
Scroll lock
It sounds like the touchpad wire wasn't reconnected..
May 09, 2014 | Dell Inspiron 1420 Laptop
Drag and drop disabled
Opening a new tab in chrome is normal, try using a infrared mouse manually if that works your touch pad on your laptop may be faulty.
Feb 22, 2013 | HP Compaq Presario V2000 Notebook
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Jan 09, 2013 | Gateway Computers & Internet
Hi, I'm using K40In. I can not use the touch-pad anymore. since I realized that, I've tried plenty ways to install the ELANTECH software.... but can not. plz reply me ASAP.
There should be a function key to enable/disable the touch-pad (Fn and one of the light blue keys usually "F" keys) try to look through the keys and see if you have the pad turnned off, if it was a windows update theat stopped it from working then you should be able to roll it back to a working order from a system restore point. Go under the start menu select accessories, system tools, system restore then select the restore point at which you remember the touch-pad still worked.
Jun 30, 2011 | Computers & Internet
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
I have erased my shortcut of Microsoft Word from the desktop. I didn't realized that when I dragged the MS Word from the start up menu, it moved it from the list and not copied the shortcut. Now I couldn't...
Right Click anywhere on your desktop and choose New>Shortcut
Type in C:\Program Files\Microsoft Office\Office12\WINWORD.EXE
Click on Next, and Finish. You have now created a shortcut to Word. You can drag this to the quick Launch bar next to the Start Menu if you want - It will not delete it but create a new shortcut there
Hope that helps, pls rate the solution
Nov 11, 2010 | Microsoft Office Word 2007 Full Version...
Laptop touchpad scroll doesnt work
First see is it Your Laptop Touchpad driver installed or not..If driver is no installed it gives this type of problem.so install touchpad driver for Your model
Jul 02, 2009 | Computers & Internet
Scoll bar action on touchpad works outside the scroll area
Seems like the synaptic touch pad has lost its configuration or got a little whacky.
Go to the control panel, and find the program for the touch pad.
There, try to redefine the areas for the scroll bar action.
Oct 18, 2008 | Computers & Internet
Turn off scroll button
hold down the fn key and press the scroll button.
Oct 11, 2007 | HP Compaq Evo Notebook N115 (470035-737)...
HP Pavilion dv4170us Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
