Question about HP Officejet 4110 All-In-One InkJet Printer
Printer problem printer says it is "out of paper" after I've loaded paper. I've tried reloading the paper dozens of times but it continually says: "out of paper"
  • 2 more comments
  • Anonymous Jan 08, 2009
    my 4110 printer from hp says i need to load paper when there is paper there. what can i do?
  • tjr27 Jan 19, 2009
    Message says "load paper" even though paper is loaded.
    Tries to feed paper, then displays message.
  • Anonymous Mar 18, 2009
    The printer says out of paper, when paper is clearly inside the tray...
  • Anonymous Apr 07, 2009
    there is paper and the message is that there is no paper, everuthing is clean, no jams,
    Carlos
I have the same problem
Posted on May 17, 2009
Canon mg2120 will not print online
I just installed a canon mg 2120 printer to a new toshiba pc with windows 8. canon box and retailer It shows it's compatible. Went through all installation process, but printer keeps saying that it's "out of paper". I've loaded and reloaded the tray a dozen times. Printer just won't catch paper and run through the machine. What's wrong???
Dec 31, 2012 | Canon PIXMA MG2120 - multifunction ...
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
NO PAPER FEED
This is a design flaw with this printer. Try stretching and/or replacing the two coiled compression springs under the output flap of the paper tray. This should work for a few weeks, then you'll have to repeat the process. I stocked up on a few pairs of springs at Ace Hardware.
It's a shame, because the print quality on this printer is superb, considering the price, but dealing with this issue is a real pain. I've replaced the springs 3 or 4 times, and I haven't even used up one toner cartridge yet. I'm on the lookout for a replacement low cost color printer. I would never buy a Samsung printer again.
May 20, 2010 | Samsung CLP 300 Laser Printer
Out of paper displays on computer when paper has been reloaded
Usually when you run out of paper the driver changes its status to "paused" just right click the printer and select "resume"
Mar 24, 2010 | Office Equipment & Supplies
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
the left edge guide, and that the paper isn't jammed in the printer.
If the Paper Out light is on solid, reload the paper, making sure
the paper edge guide is adjusted to fit the paper's width, and then
press the Load/Eject button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload
the paper, turn the printer back on, and try pressing Load/Eject
again to see if the printer will now successfully load the paper.
If the printer still will not load paper, power the printer off,
remove the printer cable, and make sure all of the packing materials
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
LED BLINKING
Replace the communication cable (parallel cable).
Dec 11, 2007 | Epson FX 1170 Matrix Printer
Paper problems
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
163 people viewed this question
Seeker5211
Seeker5211
