Question about Panasonic PT-47WXC43 47" Rear Projection Television
Another question The power light will come on to the tv but it then it kicks right back off flashes quick times then it pauses for about 6 or 7 seconds and it will flash quick three more times. Nothing will appear on the screen any suggetions.
  • 81 Answers
You can pull the plugs inside tv to convergence yoaks if tv starts up . you will need convergence ic,s
Posted on Apr 15, 2007
    President:
  • 1,284 Answers
What is the amount of times it flashes?
Posted on Apr 14, 2007
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
TV power loss
most likely the part inside the tv has gone bad as you said that you heard a pop and this lead to take the tv to a technician.
Apr 29, 2008 | Televison & Video
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Tv is in standby mode (red light on bottom left is blinking). we can't get it out of this mode. We moved the tv and unplugged it...tried to turn it back on and this happened.
I need a model or chassis no. (on the back of the TV). Also how many times does the light flash between the long pauses? Sonys have a self diagnostic feature that flashes the power light a certain number of times to indicate various problems.
Dec 04, 2009 | Computers & Internet
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have an orig 60K mile 1988 chrysler conquest tsi automatic that for some reason shifts extremely hard (its either the shifting or the turbo is kicking in to early) im not sure. and there is oil in the...
First thing I'd do is have transmission fluid & filter change done and add only autopar transmission fluid to it, ATF4. Get them or you to make sure they lube all linkages (especially throttle valve cable area, well as some can stick over time & cause problems like your describing. Secondly, cycle your key from off to on, (not start, just to on) back off, back on, back off, back on & leave it on & count flashes from check engine light. It will be 2 digit number but small pause in between, for example: 3 quick flashes, then a pause, then 3 more, will be code 33. 2 quick flashes, pause, 5 more flashes is code 25. when you get 5 flashes, pause, 5 more, thats code 55 which means end of message. Get back to us with results for more info on what to do. These should point everybody in right direction for any trouble your having.
Aug 09, 2009 | 1988 Chrysler Conquest
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
