Question about Real Digital RD2200 22 in. HDTV-Ready LCD Television
Need code for universal remote for a Real Digital RD170S1
Need to program a universal remote for a Real Digital TV, Nidek RD170S1 and type nt1702
I have a rcu404 universal remote. I'm trying to program it to my apex502digital converter box
Unfortunately, the RCA RCU404 was programmed in 2003 before the digital-to-analog converter boxes were released. It doesn't have a code for any brand converter box. The Apex converter boxes were listed at Amazon in 2004. See to search for all available device codes. Change the Product Type via the drop-down menu for other device codes.
Most universal remotes code lists are limited to devices that hit the market 6 months before the remote was programmed and older devices. I wish that I had better news for you. A universal remote that was programmed later (2005 at the earliest) would be more likely to support the converter box and let you consolidate all of your remotes.
I hope this helps.
Oct 05, 2016 | Universal Televison & Video
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
NH305UD. How can I program it?
Universal Remote Control Codes - Emerson Instructions
Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For ... Emerson multi-brand remote codes for tv's.
Remote Control Codes For Emerson TVs ' Codes For ...
2 & 4 Digit Universal Remote Control Codes For Emerson TVs Emerson multi-brand remote ... How to Program a Universal Remote Control : Universal RemoteProgramming of TV ... Can you give me the code for Western digital TV box please.
Emerson brand TV remote codes - Comcast Help and Support Forums
May 22, 2010 - I have a Emerson TV model # BLC320EM9 A and I cannot find a ... ..... I can not get 11864 to work with the silver xfinity remote that has the ..... Code 11864 was not listed in the program guide.
Dec 25, 2015 | Emerson Televison & Video
Codes for a rca converter box remote control
Try using directv's :remote control code search engine)search for "Directv remote control programming" enter your device type and it will give you the most recent code for your device
Mar 08, 2014 | RCA Universal Tv Digital Converter Box...
Rcr311w need help and advice on programming
Jun 03, 2009 | RCA Universal Remote Control
How to program an RCA RCR450C. I also need codes for a tv Hitachi 27SC48 adn a Magnavox CCR136AT02
The REAL solution. The link below is the manual to the RCR450. It shows a pic of the remote which is exactly like the RCR450C. This will teach you how to program the remote and it gives you the codes for the different types of equipment for the universal remote. When the web page comes up, click on "click here" that is in red. Save this manual in your Adobe files for future reference.
Jan 07, 2009 | RCA RCR450 Remote Control
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Real Digital RD2200 22 in. HDTV-Ready LCD Television Logo
273 people viewed this question
Top Real Digital Televison & Video Experts
Are you a Real Digital Televison and Video Expert? Answer questions, earn points and help others
