Question about Nokia 3230
How can i format my nokia3230
How can i format my cellphone coz its says"phone start up failed contact the retailer" how can i solve that?? the technician said tome that my celphone has its own phone format how can i do tha????/ on my own without any assistance in a technician?
Just to make the suggestion a bit clearer, 1. switch phone off, probably take out the battery if the power button doesn't work. 2. hold down call (green), 3 and * all at the same time. best with right hand. 3. turn phone on. with left hand. 4. wait a bit and phone will come up with formatting. does take a bit, so be patient.
Posted on Apr 22, 2007
  • nobertjazel Nov 26, 2010
    thank you so much.. it help us a lot
Keep pressing green(call),* & 3.switch it on hold the keys while it shows FORMATING
Posted on Apr 19, 2007
Phone start up failed contact the retailer
Posted on Aug 30, 2009
I don't have anything to say, just thanks alot .
my phone's software was detected by a virus and it would never switch on , i made what you said, it was formatted and switched on correctley , thank you very much .
Posted on Nov 19, 2008
Do we have to put sim card , when we switch it on , if we put ill the contacts in the card be deleted
Posted on Apr 26, 2007
Bakit po bumabalik ung phone start-upfailed? e naformat ku na po?
Posted on Jul 29, 2011
Switch off the phone remove the memory card on the phone and press *#7370#
Posted on Aug 09, 2007
    Problem Solver:
  • 4 Answers
My phone nokia 3230 has run out of phone memory I try to delet files from phone memory but nothing happend.I don't have any files to delet, I deleted all but he still shows that he dont have enought memory
Posted on Mar 07, 2009
SOURCE:
Phone start-up failed.contact your retailer..prompting when phone is opened
Use this trick ,it can solved 90%.Press and hold 3 keys i.e. Green, dial key, *, Star key, no. 3 , key on keypad and then press the power on/off to switch on the phone.Examine the battery backup of your phone. Remember, do not let go the 3 button i.e * + 3 + green just press and hold keys until you see a formatting word screen shown........But in N series don't release the three button until the time set shown . original system and factory setting has also done automatically.There is no guarantee coz it might not work with some phone.............................................Try and Enjoy
Aug 29, 2011 | Nokia N73 Cellular Phone
Nokia e5 reads phone start up failed. contact your retailer
If you don't accidentally drop your phone, it's that you're phone has a defective software. you need to reprogram it. and its kind of a thing that only cellphone technicians can do it for you.co'z they have special tools to used.
Jul 17, 2011 | Nokia E5 Cell Phone
Nokia 6600 classic
contact the retailor they will help you cause thats what the phone said to do... goodluck:)
Jun 06, 2010 | Nokia N71 Cellular Phone
Phone startup failed Contact the retailer.Nokia N91
Problem: Nokia 7610 startup failed contact the retailer
Solve: You Need to format your mobile and this is the way
First of all Turn Off Your Mobile Phone
[ format = power + press & hold call + * + 3 ]
Jul 19, 2009 | Nokia N91 Cellular Phone
Mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Jan 13, 2009 | Nokia 6600
if it is a series 60 phone than try holding the following keys together (1);-green key(calling key)
(2);- 3
(3);- *
(4);- on\off switch
keep holding them till it shows formatting the will take some time then it will restart ur battery must be charged for this process
May 23, 2008 | Nokia 6630 Cellular Phone
3230 start up failed
u need to format it manually by pressing power on, call options, 3 & * simultainously tested and proven!
May 06, 2008 | Nokia 3230 Cellular Phone
Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
Jan 20, 2008 | Nokia 6670 Handheld
Nokia 3230 start-up failed
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye sr99mobiles@yahoo.co.in
Sep 11, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Logo
650 people viewed this question
Top Nokia Computers & Internet Experts
k24674
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
