Question about Southwestern Bell Landmark DKS930 Corded Phone (swblandks930)
No ring for some phones after power outage- dks 930 phones
Some of our front office phones don't ring after we had power outage. phones are dks 930 Landmark
  • Anonymous May 15, 2009
    I hit next, but ringing assingmetn is not a choice?
  • Anonymous Mar 25, 2014
    we have several phones in the office and only want it to ring in the front. the phone in one of the office is ringing everytime a call comes in. how do I stop this?
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Posted on Jan 08, 2009
Samsung Prostar 816
Did you try unplugging power cord for five minutes? often this fix the problem.
Aug 12, 2008 | Samsung Prostar 816 Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Need manual for setting up swb landmark dks 930 phone
F#*000000 IS THE PROGRAMMING ACCESS FOR THE LANDMARK. YOUR SHIFT KEY ON THE PHONE IS ACTS AS THE BACK KEY, TOP OF MENU KEY. ONCE YOU GET INTO PROGRAMMING, GO TO RESOURCE MENU HIT SHOW, THEN NEXT TILL SYSTEM TIME APPEAR, HIT SHOW, THEN CHANGE TO ENTER TIME. USE THE DISPLAY WINDOW TO HELP YOU .
freddy@lumbrefutbol.com
Nov 06, 2008 | Southwestern Bell Landmark DKS930 Corded...
Samsung Prostar 816
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Inactive Feature
The system lost programming. Call a vendor in...
May 07, 2008 | NorStar M7310 Corded Phone
Office phone, IBM-412CID, had power failure, reset phones, now cannot remove DND without constant ring
Must reset all extensions with individual extension numbers after a power outage. Just the same as starting the phone out of the box. Thanx.
Apr 28, 2008 | TT Systems Lands Phones
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Mar 19, 2008 | Samsung Prostar 816 Phone
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
Ring and paging system
I have seen cases where programming can be messed up or even set back to default with rapid on-off-on-off power surges that often happen in power outages. The system will need to be re-programmed. I have never programmed an NEC system but here is what you need. Either find a local installation company that can fix this for you OR figure out which NEC phone system you have and locate the Programming and Installation manual for it. (not a user guide or administrator's manual) The phone's part number will not help you figure out which NEC system you have, it only narrows it down a bit. Look for the main control unit in the basement, utility closet, etc.. Programming any phone system can be daunting for someone who has not done it before even with the right manuals. If you are not up to it, look for a company that can help. MAKE SURE the system is defaulted before re-programming it! There could be a glitch in the programming that cannot be fixed without a system default so you want to do this before making any changes. Also, I would highly suggest a UPS backup power supply for the phone system. This will keep it running for a short time in a power outage and will stop this from happening again. If you have a small system with 1-12 phones, most small UPS systems made for computers will work. Small phone systems use less power than a computer and monitor.
Aug 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Southwestern Bell Landmark DKS930 Corded Phone (swblandks930) Logo
564 people viewed this question
Top Southwestern Bell Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
