Question about Motorola Mobility RAZR V3
RAZR2 V9M Wonky Screen =//
I dropped my phone early on when I got it but there was no major damage
just a few hairline cracks where the camera lens is && even then the camera was not affected. But I remember I was in the middle of class one day [it's been a while since my phone has been like this] but the screen got stuck. So i turned it off thinking it was just glitching like an ***. But when I turned it back on the screen never popped up. The sounds work perfectly fine. It vibrates, I can take calls just the screen itself refuses to work. Both outer && inner are bunk. The back light works && I can see it lit up when the phone is on. This is a very frustrating issue && I really do love my RAZR2 besides this problem. Is there anyone who knows how to fix this? Any parts? Good affordable repair services?? Thanks.
    Brigadier General:
  • 7,752 Answers
The flexcable needs to be replaced on the phone
Posted on Dec 26, 2008
My Motorola RAZR2 V8 inside screen has blacked out, it flashes back with my wallpaper for a short amount of time and I want to know how to fix it
you need a new LCD and the professional Tech to change it because It is very easy to damage the Flexible cable that adhesived to in -LCD and out - screen. Good luck
Sep 30, 2010 | Motorola Mobility RAZR2 V9m
I have a motorola razr v2m, and both the outer screen and inner screen are blacked out. I can still make calls, if I know what number to put in, and I can still receive calls, but with out knowing who is...
Basically only your display is damaged/broke.So all your functions are working well.Please replace the display with the new one so that everything will be fine.
To replace please go to nearest motorola authorized service centre.They will replace the screen for you.
thank you
Aug 07, 2010 | Motorola Mobility RAZR2 V9m
Screen is black
LCD is not working and need the new one.
Jun 05, 2010 | Motorola Mobility RAZR2 V9m
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Mp3 driver motorola sliver L7c vista pro
I found these drivers for XP here: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_32.zip
And for Vista drivers, use this address: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_64.zip
Alternatively, you can download and install the USB Drivers from http://developer.motorola.com. These drivers are often newer than the ones above, but you will need to create a user-id first. After logging in with the new user-id, search for "usb driver", or navigate directly to http://developer.motorola.com/docstools/USB_Drivers/Handset_USB_Driver
After downloading and installing the Motorola Driver, you will need to run the Motorola Driver Installer program by going to "Windows->Start->Programs->Motorola Driver Installer->Motorola Driver Installer.exe".
This alternate Motorola USB Driver is required for most phone models from Verizon, Alltel, and US Cellular. Some of these models include:
Alltel V3a, Verizon K1m, Verizon Maxx Ve, Verizon L7c, Verizon W385, Verizon W755, Verizon Razr2 V9m, Verizon V750, Alltel Razr2 V9m, US Cellular Razr2 V9m, Sprint V3m, Sprint K1m. I hope this helps someone. :o)
Jul 03, 2008 | Motorola Cell Phones
Blurry camera screen
If the pictures are blurry, you probably damaged the lens with the drop. You will have to send the camera to the factory service to replace the lens unit, if it is not serviceable.
If you drop a camera this is not normally covered by the warranty. You may find it cheaper to replace the camera than have any major service done to it.
Jerry G.
Apr 27, 2008 | Cameras
Three problems...
1. You may have water damage this would explain all of the problems. 2. I doubt very highly it's your carrier 3. If you have dropped your phone, your camera lens may be cracked causing the screen to pick up primary colors, or once again it's water damage. If the screen does different variations of color in different patterns or only partial images... the lens is cracked. Otherwise... YOU'VE GOT WATER DAMAGE... say goodbye to the Razor.
Jan 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
