Question about ViewSonic VA520 15" Flat Panel LCD Monitor
ViewSonic VA520 15in Monitor-Beyond Faded
I have a compaq presario that a new hard drive was installed in yesterday. I plug everything in, however, the View Sonic VA520 shows the Windows start barely on the screen which can hardly see the icons. When I press the Power button on the screen, The icons flash bright in color for 1/2 second then beyond faded again.
I have a deadline I'm working on and would appreciate all the help I can get.
Thank you
Bobbi
SOURCE: vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
Posted on Jul 13, 2007
Riziel
  • 116 Answers
SOURCE: LCD Monitor has no video
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Posted on Nov 26, 2007
cashmerekay
SOURCE: Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Posted on Dec 18, 2008
  • 12 Answers
SOURCE: vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Posted on Aug 05, 2009
mace1mace
  • 1138 Answers
SOURCE: Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
Posted on May 24, 2010
Need apower supply and hard drive for my compaq presario 1103WM. how old is this unit
It must be up to 8 years old ish as it has XP installed.
17-inch flat screen CRT monitor NEW* Intel Celeron D Processor 3252.53 GHz, 533 MHz FSB, 256 KB L2 cache 256 MB DDR SDRAM CD-RW (48x32x48) 40 GB hard drive 9-in-1 memory card reader 10/100Base-T networking interfaceIntegrated graphics with 64 MB shared video memory *The new Celeron D processors are more efficient than the old Celeron processors. The New 325 D benchmarks faster than the old Celeron 2.7 GHz processor.
Almost any IDE hard drive will work, up to 540Gb and any reasonable power supply should be OK. Check ebay and also google for a power supply.
Hope that helps.
Feb 16, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
The compaq will not boot up
try loading your OS cd but it will wipe out all the files on your drive. if this wont still work, then it might be prob with the hard drive itself. replace hard drive.
Mar 31, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
My acer monitor image is faded and washed out
Adjust contract and luminosity: decrease contrast, see how it goes.
ACER monitors tend to have control settings that are out of the range for proper viewing.
Jul 15, 2009 | Acer X191WSD Monitor
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
Compaq Presario S0000/8000 Series hard drive won't turn on. Green light on back is blinking. Power strip is working, modem, monitor and speakers getting power and working?
is the power supply working have u recently installed a new hard drive or cd rom need to make sure that the wires are securly plugged into the drive and into the board and are plugged in to the drive correctly if this is all ok you may have to get a new drive
Aug 14, 2008 | Computers & Internet
Installing a second hard drive in a compaq presario 70000t
laptop dont use two hard drive if you want to use second hard drive you make it an external
Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Presario 1693 issue
Go to (CMOS) Setup at boot and "detect" your new hard drive.  Then boot from your operating system CD and prepare (partition, format) your new hard drive and let your OS install.
Oct 15, 2007 | Compaq Presario 1693 (153296-007) PC...
ViewSonic VA520 15" Flat Panel LCD Monitor Logo
60 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
