Question about LG WM1812C Front Load Washer
LG front load washer
When you clean out the front filter their is a rubber hose with a cap. What is this? and what do I do if anything with it?
Pull the hose out (leave the cap on) find a low tray and place the end of the tube in it. Take the cap off and water will drain from the filter, so that you don't get a mini flood when opening the filter housing if it got blocked.
Posted on Sep 02, 2007
No response no light come on but same time it ok i dont know why thanks
Posted on Apr 14, 2007
    President:
  • 1,294 Answers
Go to troubleshooting above, you might find a solution.......
Posted on Apr 13, 2007
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
My washer is leaking water out the bottom and after cleaning the filter it is still leaking with no visible signs of a bad hose.
very hard to solve without looking but when you cleaned the filter is the rubber seal around it in good condition?
Feb 07, 2011 | LG WM-2277HW Front Load Washer
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
LG 2455 washer - error OE but filters are clean..
check to see if you have a kink or, obstruction in your drain hose; hot wash the drain hose with 1/2 cup of hot vinegar
Jun 10, 2009 | LG WM-2277HW Front Load Washer
Filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
May 03, 2009 | Samsung WF203ANW Front Load Washer
Smelly wash
it is a known problem that this machine has. There is a some what strange solution for it. First check if your machine is level. This normally happens with machines which are not level. Clean out your filter located at the front. Open the door. get a container and pull the white cap of the black hose and empty the water out. Clean the filter after all water is gone. If this does not fix it:
Clean it out as before. put filter back. get with garden hose or bucket water in your machine through the door opening. Pull the little white cap of and let it run out. Do this again for 2 times.
Now put some bleach in your machine in the soap dispenser and let it run the spin and rinse cycle. It should be gone or at least way better.
Apr 06, 2008 | LG WM-2277HW Front Load Washer
LG WM1812C Front Load Washer Logo
59 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
