Question about Bosch Dishwashers
Dishwasher not taking on water - Bosch Dishwashers
    President:
  • 2,110 Answers
Water does not go into the machine through a pump, but through an electrically operated valve. Maybe your valve is stuck through lack of use.
Posted on Dec 24, 2008
  • 275 Answers
Did you check the pipes connecting to the watter supply?
  • 13,433 Answers
If there's no water entering your dishwasher, check these:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
Apr 30, 2012 | NEFF S54T09X1GB Fully-Intergrated Full...
My dishwasher (bosch) is not taking in water. Can you help
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 13, 2010 | Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Dishwasher wont take water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwasher cycles are taking too long
usaully water temperature is the major reason why a dishwasher takes longer this could be due to the water tank.To verify this open hot water valve and let it run on your hand and count the seeconds it takes to get so hot your hand has to pull out. Between 10 to 20 sec normal, 20 to 30 means dishwasher has to heat it up and this takes longer but acceptable. 30 to 60 this would really impact the time of your cycles. Now regarding the sauce pans this surprises me this could be the dishwasher internal water heater which would let be belive that water level is too low or even absent you need to let it fill up and while it is operating stop it open the door and see if water covers the heater. I do recomend that you schedule a technical service expert to verify your unit
Mar 20, 2009 | AEG 24 in. Favorit 40660i Built-in...
Dishwasher not taking in water
there is no water going in only wants to pump out also the green on light is flashing
Nov 24, 2008 | Dishwashers
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Nov 12, 2008 | Zanussi Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
