Question about Cuisinart DLC-2 Mini Prep Plus Food Processor
Lid stuck on bowl of my Cuisinart Mini Prep Plus.
I took the bowl off the processor and cannot get the lid off the bowl. It won't unlock.
  • 1 more comment
  • Anonymous Jan 10, 2009
    i have the same problem
    how do you get the lid offthe bowl.
  • Anonymous Apr 24, 2009
    I have the identical problem. Tried cooling it in fridge, then freezer .... leaving it under running hot water . .. and using various tools.
    It has been sitting in the fridge for three days with its contents of pureed tomatoes that I can't get out.
    What has Cuisinart done?
    I used an earlier model for seven years with no problems until the circular blade broke.
    Surely there's some solution -- other than spending $18 on replacing part of a product I've only used for a month?
  • 8,596 Answers
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Posted on Mar 20, 2009
Need user manual
Google DLC-2 Mini Prep Plus Food Processor manual and you get https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=DLC-2+Mini+Prep+Plus+Food+Processor+manual
May 03, 2016 | Cuisinart DLC-2 Mini Prep Plus Food...
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
The lid for my mini cuisinart hit the tile floor and broke. I need a replacement. I live in Vancouver, British Columbia. Do I buy it on line, or in a store near by. Thank youNora
We don't stay in the same vicinity, so I don't know precisely where you can get the replacement. So I would suggest you order it online.
Click on the below link to order for the replacement.
http://www.kitchenworksinc.com/Cuisinart/Cuisinart-Mini-Prep-Parts.aspx
Please let me know if your need more assistance....
Regards.
Aug 24, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Often it is difficult to unlock the bowl on the cuisinart food processor
Have you tried removing the lid first? Mine has an interlock where I have to remote the lid before I can unlock the bowl from the machine. Good luck!
Sep 20, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-2 Mini Prep Plus Food Processor Logo
2,057 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
