Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Will not restart. Ignition lite flashes
Reddy heater model# 016920475 heater fired first time after sitting for maybe a year. I cut it off after about 15 minutes. after aprox.20 minutes I tried to restart and it would not. The ignition lite blinked off and on. Following the instructions on heater it still would not restart. What can I try. Thanks for your help. E-mail add. wd1webb@yahoo.com
    Problem Solver:
  • 6 Answers
Actually if there is a ignition LED then this model uses the hot surface ignitor.
The control is indicating that the HST is unplugged or broken. Check the wiring and look inside the ignition chamber for tube of white ceramic with some metal sticking out. if there are two distinct pieces of metal sticking out then the ignitor is broken. It should look like a rectangle with one end stuck into the ceramic.
Posted on Jan 09, 2009
Fuel oil/ kerosene torpedo heater?
Posted on Dec 25, 2008
  • iamthesnake Dec 25, 2008
    Pull out the spark plug to see if it is fouled/black goo/electrode burnt
Runs 6 seconds cuts off never lites
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Will not light getting fuel through nozzle ignition lites changed fuel
maybe getting to much fuel is there away to turn down fuel or does it have a hot enough spark plug
Jan 26, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
What makes the heater start up then cuts off after about 5 seconds with a little of kersone running out of the front of it
This is normal. It has a time limit to fire off. The heater will cut off if it does not light.It sounds like it is never lighting up. Check your ignition source. I am not sure if you have a spark plug type or a glow bar.
Jan 03, 2011 | Reddy Heater-30-55,000 BTU Variable
Fan starts no ignition then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jun 08, 2010 | Reddy Heater-75-125,000 BTU Variable
Unit fires for 30 to 45 sec then cuts off
heatman101
Jan 13, 2009 | Reddy Heater-30-55,000 BTU Variable
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
78 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
