Question about Garmin StreetPilot 2720 GPS Receiver
FIXED! Garmin 2720 Power Cable Defect
I've read many posts on the web where people had their 2720 suddenly shut off or lose power when driving or if they hit a bump in the road. Some had Garmin replace the cable, but most purchased new power cords or bought new units. I have had my unit exactly 2 years and all Garmin would do is offer to sell me a power cable or direct me to a vendor. I think this is very poor customer service since there is an obvious design flaw in their connector.
I wish I could post a before & after photo, but not sure how. Anyway, the defect is in the connector that attaches to the unit. There is a thin plate attached to the end of the power cable that has begun to separate at the bottom of the connector making the brass contacts lose connection with the contacts on the unit. Here is the fix: I simply used super glue around the entire edge of the connector and clamped the plate to the connector over night. I also used fine steel wool (not SOS pads) to clean the contacts on the back of the unit. Next morning, I unclamped and connected the power cable to the 2720 and everything worked great. In addition, the thin film of super glue made an even tighter connection so there is absolutely no wiggle in the connection. Side note: Make sure to check the cigarette lighter adaptor. The tip should be screwed down snug. I hope this helps someone save $45. Good Luck!
  • Anonymous Jan 11, 2009
    My Garmin 2720 will not power up most of the time then it gets locked MAPS. I noticed a connector pin on the plug looks like it is broken does anyone have a similar situation and does buying a new cable seem to be the best fix for me? Thanks
  • Tom 2720 Jan 24, 2009
    Just a caution, that's gold plating, it won't tarnish so you shouldn't need to clean it.
    Scholar:
  • Garmin Expert
  • 186 Answers
Thank you for the tip. Sorry for the trouble you had.
Posted on Apr 12, 2017
5 Suggested Answers
  • 504 Answers
SOURCE: garmin 250 first gave low battery warnings, now
The battery on your GPS is NOT user servicable. You should contact Garmin at www.garmin.com to inquire about getting the battery replaced.
Posted on Jan 15, 2010
Testimonial: "I know it says that on the device info, however, with a screw driver, I opened the unit, unplugged the battery and removed it. So, why not servicealb"
fathitkf
  • 1871 Answers
SOURCE: power cord bad connection to unit
Hello :
I think you have a problem with the charging jack . For that you need to call Garmin or get your device serviced .
please rate !
Posted on Apr 16, 2010
SOURCE: Power plug broken, missing parts to get power
Eloise, did you ever find a solution to this problem with yur Garmin? I have the same problem and don't want to spend $40 for an entire mount. Let me know, you can email me at JeffWang3@gmail.com. Thanks!
Posted on Jun 23, 2010
  • 6771 Answers
SOURCE: My wife used our Garmin
No! you are further ahead replacing the unit.
Posted on Jun 09, 2011
I need a new automobile power connection cord for my 2720 (2006)
Vehicle Power Cable with External Speaker 010-10477-07
$ 44.55 https://buy.garmin.com/shop/shop.do?pID=6387#accessoryTab Go to the Garmin site shown and order the part number above!
Oct 28, 2010 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 lost sound
do not buy any this product garmin does not warranty or stand by its products, if have this fixed it will cost 300 but if you buy a new gps it will cost 150.00 can you understand this ?
May 09, 2009 | Garmin StreetPilot 2720 GPS Receiver
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Unable to update unit
When you plug in the USB cable, if your System, Hardware, Device Manager lists "GARMIN Devices", then the problem has to be in your network connection or Garmin WebUpdater. If your Device Manager doesn't list "GARMIN Devices" then the problem is in the computer, USB cable, or 2720.
I have three 2720s right now with bad USB ports. I'm going to try replacing the USB driver chip in each unit, but now I'm just guessing. Hope this helps. Tom
Dec 30, 2008 | Garmin StreetPilot 2720 GPS Receiver
It sounds like the audio power amplifier is failing in the unit, it's kinda classic for an audio amplifier to fail when it gets hot, then work again when it cools down.
I'd suggest deleting the language you're using, then reload v7.2 firmware and the language. No reason why this should work, but it doesn't cost anything. If not you're looking at a $250 Garmin flat rate repair.
Dec 22, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
Gps 2720
I tried another power cord and that was not the problem. I did do a firmwre update and that corrected the unit. It has been working well for the past 3 weeks. You should go to the Garmin website and download the latest FIRMWARE update.
Oct 02, 2007 | Garmin StreetPilot 2720 GPS Receiver
Shuts off itself
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Sep 03, 2007 | GPS
Garmin StreetPilot 2720 GPS Receiver Logo
1,507 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
