Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
The tope rack was not cleaning well for a couple of weeks and then the bottom and top stopped cleaning all together. There is water in the bottom but when I open during cleaning cycle there is no water dripping from the top or bottom rack.
  • keith_mcgowa Jan 06, 2009
    On the money except the blade was also cracked. $20 and everything was fine
  • 9 Answers
The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
Remove dish baskets
Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
Remove bottom plastic assembly. - Remove 4 screws and lift off.
Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
Posted on Jan 05, 2009
  • 338 Answers
You motor housing is clogged up with debris. you have to clean it out. should only take roughly 45 min..
Posted on Dec 25, 2008
Why is my Bosch dishwasher not washing on top rack
Maybe the pump isn't working to its full compasity and not pushing water to higher elevation.
Aug 31, 2014 | Bosch Dishwashers
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
I have a Kenmore dishwasher, purchased in 2000, it is not cleaning the dishes on the top rack, just happened all the sudden.
You should check to make sure that the lower sprayer is extending to spray the bottom of the top rack and that water is being pumped up to the top sprayer. You will need to take the dishwaher out of the cabinet to test.
Jul 15, 2011 | Kenmore Dishwashers
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
Kenmore Dishwasher Holding Water
lost your tube that supplies water to upper spin rack? look in your strainer
Apr 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Does not clean dishes on top rack
There is a rubber boot connecter in the back of the top rack which slips over a pipe coming up the back of the unit. This is how the water gets to the top rack. That boot is subject to rot and breaking. Check and see. It should be easy to replace, if you can get the part.
May 11, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
319 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
