Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Washing machine I was washing an apron for work and the string is stuck beneath the white pole that is in the middle of my washer. I have tried to pull it out and the whole basket inside moves when I pull it. Approx. 5 inches is stuck.
  • 57 Answers
If you pull up hard enough you will get the agitator out watch the elbows tho. they are hard to pull out but they do come out
Posted on Feb 16, 2008
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
How do I wash several aprons together without them getting tangled?
You can tie the apron strings together so they don't get tangled. Or even safer is if you put them in a pillow case and tie a knot in the pillow case.
Good luck
Jul 11, 2013 | Home
Lg wt4801cw no power cant open the lid
Check out this on YouTube. DOA and lid lock stuck locked. You pull up the top of washer and pull little red string to release lock. I was so happy to find this I wanted to share.
Apr 15, 2013 | LG WT4801CW Top Load Washers
The white button is in lock postion and I cant shut door
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Ge wpre6100g0wt washer squeaking
Basically the apron bends down to the point that the bottom of the motor bracket hits the bottom of the washer when it agitates. If this is the case you have the sagging apron issue. The kit comes with good installation instructions that are pretty much straight forward. Here is the kit to order.
Nov 20, 2012 | Washing Machines
Clothes stuck under the agitator
I have the same problem with clothing getting trapped under the agitator. Strings from Hoodies, apron strings, bra straps be caught under it all the time. There is a gab between the agitator and the tub. I have owned the machine for about 3 months, I like it in all other respects but this is crazy!! I have never had a machine that did this. GE needs to address this and fix this issue. It is NOT a matter of making sure your pockets are empty before washing, anything that is thin such as a strap or a string gets caught!! I would think twice about buying this machine if you are looking to purchase it. I don't think this machine will last as long as my others, and I don't think I would recommend this machine due to this very annoying issue.
Jul 17, 2012 | GE Washing Machines
Apron string caught under the rod the agitator sits on. How do I take it off to remove the apron string
Is it a top loader if it is.
You can remove the agitator.
Remove the dispenser pops out, you might need a flat screw driver. After that remove the cover in the agitator.
There should be a bolt. remove the bolt and now you can pull out the agitator.
Now you can get the apron string right out.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW I need to release the door lock--machine is stuck in the middle of a cycle likely overloaded. Will not unlock when i pause or complete the cycle. I have pulled out dispensing...
open the dispenser door you will see a green piece of plastic,pull on it and the door will open.it may be in a little you will have to reach for it it looks like heavy string.
Dec 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
370 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
