Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from
most local telephone service providers. You must subscribe to these
services in order for the features to work on your phone. Contact your
local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters
must be plugged into EVERY phone jack that has a phone. The DSL signal
can cause caller ID disruption, static, noise and other issues on your
line. DSL filters block the high frequency DSL signals from being
transmitted to the telephone. If you are not using the DSL filters
provided by the telephone company, this will cause static/noise and
possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL
filter into the telephone jack, then connect a telephone cord between
the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call.
Common reasons are incompatibilities between your and your caller’s
service, transmission errors and answering calls before the ID data is
received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
(1) When receiving a call, no Caller ID shows and the display shows only "Connecting", making Caller ID feature worthless. Therefore, can't answer the phone until after the outgoing message plays and I can hear who is calling. Many friends hang up, thinking we are not available. Also,
(2) Phone is set to answer on 2 rings, but will connect only after 4 rings.
Combination of (1) and (2) drives friends up the wall.
(3) Handset shows "Out of range", even though the call may be from my own cell phone (within 1 mile), and all handsets are within 10 feet of the base.
This weird behavior started just about 2 months ago, after the phone having worked fine for over a year.
Called the phone service and they don't have any idea what is causing the problems, other than that they are sure they are not the cause.
I have same problem with my Uniden DECT HAndsets and base. Called ID doe snot work, andthe arrrow keys on the handsets do not work.
Any assitance is appreciated!
