Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Why does my ce-200 beep every few stitches?
Singer ce-200
we cannot sew a straight line without the machine beeping every few
seconds
  • crimsonkn116 Jan 04, 2009
    I having the same problem and I really want to find out how to fix it. Ive tried everything from threading a bobbin correctly to making sure the thread tension control is on "S". I can sew at least but its annoying having the sewing machine stop and blink every 2-5 seconds.
I was having this problem for two days so I just called Singer and got a solution!  I'm posting it for you because I was on here looking for a solution to the problem and nobody had posted one.
Take the top thread out of the machine - cut it back by the spool and pull it out through the machine the way the thread goes when you are sewing - you don't want to be pulling the thread back through the machine because dusty bits are getting stuck up in that part of the machine with the frosted plastic where you have to make sure the thread is pulled into when threading.  You might not think there is dust in there - I didn't because I had taken that part off and brushed it out but that didn't work.  What you need to do is floss that part of your machine.  Get some dmc floss or some UNWAXED dental floss and pull it into that part of your machine - under the pieces that are under that frosted plastic part on the top of your machine - now floss it back and forth for a good 30 - 45 seconds.  When you are done that pull it out to the left - the way the thread goes when the machine is sewing - remember pulling the thread back the other way will get fuzzies stuck in there.  I rethreaded the machine carefully and made sure that the thread got pulled into that top part properly - the lady on the phone said it may feel differently now that its been cleaned out.  Then it worked again!
I hope this works for you!
Posted on Feb 26, 2009
What causes the Futura CE100 to beep constantly?
It may need to be re threaded or the stitch length is not right.
May 25, 2014 | Singer CE-100 Futura Computerized Sewing...
Does not stitch, just beeps
try changing the needle
try rethreading the machine top -make sure to use every thread
guide & bobbin--make sure the bobbin is turned the right way in the
bobbin case
clean under the needle plate & in the bobbin area for lint
also try turning the machine off & then back on & see if that will
help
Oct 07, 2012 | Singer CE-200 Quantum Futura Computerized...
It keeps beeping when I am sewing a straight stitch it say E1
E1 means the machine is out of order, usually turning the machine off & then back on clears it,unless there is something wrong with the computer part of the machine
Sep 20, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer futura beeping every 8 stitches can you solve this .i have changed needles bobbin cases but still doing it but is sewing ok just stops to beep
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Feb 07, 2010 | Singer CE-200 Quantum Futura Computerized...
My Singer Embroidery machine works wonderfully on embroidery, but...when strait stitching or design stitching...constant error. Thought it was the tension, so I've tried every setting. Still beeps and get...
HI,
Did you make sure that you raised the feed dogs? There is a sliding button on the front that you have to move sideways to let the feedogs come up. If not the fabric is not being move right and that may be the reason of the wrong stitching.
Also, are you oiling your machine appropriate?
Dec 15, 2009 | Singer CE-200 Quantum Futura Computerized...
My machine will start sewing but after about an inch or two of stitches it beeps and stops sewing until I take my foot off the presser foot and start sewing again. Can anyone tell me how to make my machine...
If it is threaded correctly, especially on top, there is a sensor that is giving you the beep error message. Common problem but it requires trip to experienced singer tech. Sorry solution is not for consumer, too hard to get to sensors and it is not an specific action for remedy.
Jul 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
New Singer Futura machine stops & tries to revert to overlock.
Sorry to say but it sounds to me that you need to take your machine in to be checked.
Mar 05, 2009 | Singer CE-200 Quantum Futura Computerized...
My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Jan 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Unable to sew straight stictch with singer futura ce 100
When I had this experience I cleaned the thread path under the plastic cover. There was a piece of thread caught between the disks.
Aug 09, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
259 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
