Question about Sony Cameras
SONY DSC-H50 WON'T LET ME CHANGE FLASH SETTINGS ON AUTO ADJ SETTI
I used to be able to change the 4 settings and now it says settings can't be changed on this setting. On easy setting it only lets me have flash as auto and off. There are 2 more flash settings that are gone??
I am on vacation and really need help!
Thanks so much
  • dellsworth22 Jan 04, 2009
    Iam having the same problem...all of a sudden my falsh options are non existent on all settings except Easy mode. It has never been like this and I have done nothing different from when it was working...I too am on vacation and would like to use my camera on my snowboard trip...Please HELP!!!
  • damhuisr Feb 27, 2009
    All the back buttons of my camera go straight toplayback mode &I have gthe same problem as mentioned above
  • 10,594 Answers
Select upper jog dial on Auto (green mark) and have flash options.
you maybe changing desired selections which are preset on that particular selection.
let me know what selections you want to change on what settings?
Posted on Dec 24, 2008
I have a Sony Cyber-shot DSC-W90. When I try to change the flash settings, a notification pops up on the screen saying, "Flash settings cannot be changed." I tried setting it in each mode (including Auto)...
Go to Menu/ Home and initialize camera to reset it for factory default settings to fix flash light settings bug.
If problem still not solved, let me know do you see any error code flashing in top right corner of lcd?
Aug 24, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Can't change flash settings to Sony Cybershot DSC-H10 camera
Glad ur problem solved !
kindly rate my response WELL in system
Regards
Zohail
May 28, 2009 | Sony Cybershot DSC-H3 Digital Camera
Can not change my flash setting
I found on another site advice to format the internal memory.
1) Remove the memory stick
2) press menu
3) There's a tab for memory management with a Format option. Format the memory
This seems to have worked for some people. Others said they had to format the memory stick (same steps as above), but with the stick still in.
Niether of these worked for me.
But I did find an "intialize" option on the set-up menu that restores the original defaults.
After doing all 3 of these things, the flash will now work in all modes.
Feb 11, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Set camera on AUTO (green mark) on dial jog, now you can set flash on desired option.
Feb 07, 2009 | Sony Cybershot DSC-H3 Digital Camera
Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Dec 28, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
My DSC-T100 won't allow any changes to the flash setting.
The flash settings on the Sony Cyber-shot DSC-T100 are Auto, Forced Flash, Slow Syncro and No Flash, if it is not giving you a flash and wont allow you to change the setting you might have to talk to sony or the store you bought the camera from. One long shot would be that depending on what other features you are using on the camera, i could be set up to not allow you to change the flash settings in that "mode". Sorry if this is useless, but good luck and if all else fails use sony support! :)
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7
stupid hyperlink not working :(
Nov 21, 2008 | Sony Cyber-shot DSC-T100 Digital Camera
Flash not working?
I found this solution on another site and it worked for me. Good luck!
hi - thanks - you're right. I called SONY
last week. They told me to reset, as you describe. here's also what I discovered - the flash locks you out in Burst (fast frame) mode. The flash can't recover that fast. Out of Burst mode, you can control the Flash. Isn't it a much better camera with the flash?
Enjoy your W80! Thanks, Jim Connecticut, USA
Jul 17, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Okay, I figured out the answer to my own question!!!!! The REC mode has to be set on normal in order to change the flash settings. If it is set on burst you will not be able to change the settings.
Mar 02, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Cameras Logo
188 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
