Question about Maytag CWE5800A Electric Double Oven
Does my CWE5800ACB oven have a delay bake feature?
I don't
Yes see your owner manual
Posted on May 08, 2009
Kelvinator Model SF845 with Fan-King oven
contact a local repair shop to help diagnose problem you have .
Mar 01, 2018 | Ovens
Suddenly burned cakes
Could be temperature control failure
May 25, 2017 | Smeg Ovens
How to wire a cooker
If you don't have the instruction on how to do and you don.t seam to be an electrician so I would let an expert wire the stove for you. You could electrocute yourself and cause a fire.
Mar 28, 2012 | Ovens
Need wiring diagram for SMW272.
Hi I have the manual for it , I don't think it has the wire diagram , may i asked why you need it ? and i will do some diging for you , but it dosent look good ,i will need a email address to send you the one i have I don't know how attached it here !
Frank
Dec 14, 2011 | Ovens
How to fit the splashback
Hi Do you mean the screws don't match up with the holes ? I find this all the time I drill new holes to make it fit correctly. One thing you should know is stainless is very hard to drill so go to the hardware store and get a bit for stainless and also get it just a little smaller then the screws, if you bring the screws with you they will help you get the correct bit , rate this call thanks Frank
Dec 13, 2011 | Baumatic B187 Stainless Steel Electric...
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
Dec 05, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
I have an Turbochef NGC oven that keeps tripping the breaker. There are no faults but seems to only trip the breaker when the sausage setting is entered.
BEFORE WORKING ON OVEN MAKE SURE YOU TURN IT OFF AND DISCHARGE CAPACITOR.IF YOU DON'T KNOW THEN STOP HERE AND CALL TECHNICIAN.
If you know how to use multimeter than check the resistance of Convenctional heater and the IR element.
CC heater .....not sure how many ohms
IR should be 14 ohms
If both are in specification then replace breaker(thermostat in the oven).
Usually if breaker trips 4-5 times then its good to replace it.
reply me if you need more help
and don't forget to vote me.
Aug 10, 2011 | TurboChef TORNADO Electric Oven
I need to change the light in Bosch Oven HBN3260 GB but I can't the light casing off. Any ideas. I have lost the manual
Wriggle it from side to side and up and down while trying to twist it or the other trick to use is to grab it gently with a pair of grips with some kitchen roll wrapped around it so you don't damage the glass...... This is usually the way it comes off.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Bosch Ovens
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
Do i have to take out the oven racks before I self clean the oven?
If you don't take them out the high heats can wreck the finish on them and turn them all kinds of crazy colors.... but if you don't care what they look like after the cleaning you can let them in...
My recommendation is to not use the self cleaning feature...
Self Cleaning Oven Problem
It is more like a self destruct feature.... it causes many problems with ovens and ranges from the high heat...
heatman101
Apr 21, 2011 | Frigidaire Ovens
Maytag CWE5800A Electric Double Oven Logo
97 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
