Question about Lexmark T640 Laser Printer
What is 950.32 NVRAM Mismatch. I am getting this on a printer that came from lexmark in warrenty
5 Suggested Answers
  • 3 Answers
SOURCE: nvram mismatch
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Posted on May 29, 2009
  • 20 Answers
SOURCE: Error 950.10 NVRAM mismatch. how do I fix or
The way that I have found to fix this problem is to replace the logic board but when you do that, this is where the NVRAM mismatch comes in. Once you change the logic you also have to change the display op panel. That is what is giving you this error. You must change logic and op panel at same time and it will not give that error.
Posted on Apr 13, 2010
Testimonial: "Thank you very much for all your help"
SOURCE: Error 950.10 NVRAM Mismatch. Replaced the LCD
If the lcd that you put in came from another printer instead of Lexmark, it will say that because the lcd, riser card on rip board and rip board all contain nvram that has to be matched. an lcd from Lexmark will no have any nvram data and the nvram will be copied from the other two sources upon install. The only way to get the lcd out of another machine is to get all of the above parts from the same printer at the same time.
Posted on Apr 14, 2010
Printtech
  • 1087 Answers
SOURCE: changed the motherboard on lexmark
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/j3es6B
Posted on Jul 05, 2011
Error nvram mismatch on lexmark C532dn
Have you replaced any components on this printer? This error happens if you replace the display, engine card or interconnect card with one from another printer. Parts are not reusable.
Aug 07, 2014 | Lexmark C530dn Laser Printer
Forgot admin password
Hi, What you need to do is to reset the NVRAM. That will also delete your network information and passwords you set for the printer. Please see steps below: Method 1 (from Standard Menu): - Network/Ports -> press LEFT ARROW button and RIGHT ARROW button simultaneously -> Select NVRAM -> Select "Reinit NVRAM" Method 2 (with Config Menu): - Press CHECK button and RIGHT ARROW button while POR -> Select "Factory Default" -> Select "Restore Network" -> Press CHECK button If you have questions about your Lexmark printer, please feel free to contact us at LxkListens@Lexmark.com
Aug 24, 2012 | Lexmark T642 Laser Printer
Changed the motherboard on lexmark 646e and got error 950.1 NVRAM mismatch. Please help with the solution
Jun 23, 2011 | Lexmark X646e All-In-One Laser Printer
Apr 08, 2010 | Lexmark E450dn Laser Printer
954 service nvram failure huh
This is from Lexmark's support page....sounds like a hardware issue....
NVRAM Failure 953: NVRAM Chip Failure
954: NVRAM CRC Failure
Optra T 640/642/644
953 - Replace the operator panel board or upper front cover.
954 - Replace the interconnect card.
Mar 26, 2010 | Lexmark T522 Laser Printer
Jan 27, 2010 | Lexmark T640 Laser Printer
Nvram mismatch error after replacing the dislay panel on lexmark t644
Mar 30, 2009 | Lexmark T640 Laser Printer
INVALID ENGINE CODE
you can get bat file from lexmark that will reprogram the nvram chip. the problem is when those errors start it because of a corrupted control code. the nvram has reached its read write max. there is also an eprom that goes bad. we replace them both
Feb 09, 2009 | Lexmark Optra T610 Laser Printer
My Lexmark T522 printer is showing: 954 Service, NURAM Failure
info from the lexmark site:hope it helps!
Printer is Posting a 953 or 954 Service NVRAM Failure Message ID: ENUS9756
To clear an NVRAM error message:
Turn the printer off.
Leave it powered off for at least a minute to give it a chance to reset, then power it back on.
If that clears the error, continue using the printer but keep an eye on it for the next day or two to see if the error returns. If the error does not return, the printer should be fine.
If the NVRAM error does return, you can try resetting the printer's NVRAM as follows:
Now press and hold down the right Menu arrow button (>), the Select button, and the Go button at the same time.
While continuing to hold all three of these buttons down, turn on the printer.
Keep holding down the buttons until the printer displays Clearing NVRAM or Restoring Factory Defaults, indicating that the printer is performing an NVRAM clear. You can release the buttons at this point. WARNING! Do not power off the printer during this process.
When the printer has finished the NVRAM clear, it should return to the Ready mode.
If the printer has not gone back to Ready after fifteen minutes, turn off the printer and then turn it back on again as you normally would.
If these steps do not clear the NVRAM error, there may be an issue with an installed option on the printer. Electrical options (like flash memory, network cards, code SIMMS, and additional RAM memory) are the most likely causes. To see if an installed option is causing the error:
Turn off the power and remove any options that have been installed. (For information on removing memory or code SIMMs, click here.)
Turn the printer back on.
If the NVRAM error continues, the printer will probably need service.
If the NVRAM error is gone after you have removed all of the options, power off the printer again.
Reinstall the options one by one. Power on the printer each time to see if the NVRAM error returns.
If the NVRAM error returns as soon as you reinstall an option, that option may be causing the error.
Remove that option.
Turn off the printer and reinstall all remaining options (if any). If the NVRAM error appears only when that one particular option is installed, that option may be defective or incompatible with the printer.
If you can reinstall all of the options and the NVRAM error is gone, an option may have been loose and simply needed to be reseated. Again, keep an eye on the printer for the next day or two to see if the error returns. If not, the printer should be fine.
If your printer looks like it will need service and it is still covered under its factory warranty, click here for information on how to contact Lexmark Technical Support.
Nov 19, 2008 | Lexmark T522 Laser Printer
"Cartridge Error" in the display.
I got this from Lexmark this morning didn"t work for me but it may help somedody else worth a try C/P. You need to clean NVRAM on Lexmark P6250 printer. Please find below the steps to clear the NVRAM on the Lexmark P6250: 1. Press the "Up" arrow and "Menu" button at the same time. 2. Press the down arrow until the LCD displays "Clean NVRAM." 3. Press "Select."
Nov 30, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark T640 Laser Printer Logo
304 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
