Question about Lexmark Optra T614 Laser Printer
I'm currently experiencing a paper jam error 242 tray 2 on the Lexmark Optra 614 Laser Printer. Any clues?
  • 85 Answers
Try changing feed rollers in tray. To test or temporary fix remove the rubber tires and flip them inside out, then reinstall.
Posted on Feb 15, 2009
22 Paper Jam Lexmark OptraLx+
Check the rear of the printer, there is a flip down panel that exposes the fuser exit and redrive assbly (delivers the paper to the exit rollers). The paper sensors are little black plastic flags that swing in and out of optical sensors.
Jan 01, 2012 | Lexmark Optra Lx+ Laser Printer
I keep getting a paper jam error with my Optra S 1855 printer, but there is no paper jam. This error interchanges with a message asking me to Change the paer in tray 1 to letter size, but it is already...
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
Dec 06, 2010 | Lexmark Optra S 1855 Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
240 error
24x errors are paper jam error 241 tray 1 242 tray 2 ect. this means that the paper does not make it to the timming sensor inside the printer. this si usually caused by dirty pick wheels on the autocompensator located inside the drawer on the bottom of the printer
Oct 08, 2008 | Lexmark T522 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
LEXMARK OPTRA R+ SAYS LOAD PAPER 28
Try loading paper in both trays. Tray '2' is supposed to be the bottom tray. It is a much larger tray than the top tray which sits underneath the duplexer.
IBM 4039 drivers also work for this model.
Apr 30, 2008 | Lexmark Optra R+ Laser Printer
Lexmark Optra T614 Laser Printer Logo
216 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
