Question about Casio TV-900 2.3 in. Handheld Television
Digital converter box
Is it possible to connect my casio tv-900 to a digital converter box and still receive broadcasts over the air?
    President:
  • 3,085 Answers
Only if you have an ANTENNA jack.
Posted on Dec 20, 2009
TV on video can't get air TV channels
Do you have an Digital signal to analog signal converter box? if not you need to one, all signals are broadcast in digital now and your TV can't directly receive them without a converter box.
Nov 02, 2016 | Televison & Video
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Model 6620l-cta I had cable and now I don't is it possible to watch this TV without cable. Is there anyway to switch it to a TV mode?
TV is no longer analog, it is digital, which means NO over the air broadcasting for your TV to receive. The ONLY way to receive a picture on this set is to have some sort of input being broadcast, via Direct TV, Cable, etc. You could always use it as a stand alone DVD monitor if you choose. I hope this helps.
Oct 26, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Jan 15, 2009 | Casio EV-570 2.5 in. Handheld Television
I have a sony trinitron wega tv model number KV-32FS120 and I was wondering if it is digital ready or do I need to get a converter box
This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products.
Jan 06, 2009 | Televison & Video
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Casio TV-900 2.3 in. Handheld Television Logo
300 people viewed this question
Top Casio Televison & Video Experts
mikeuk
Steve Allison
Steve Allison
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
