Question about Epson Stylus CX7800 All-In-One InkJet Printer
Epson stylus cx7800
I just changed the ink cartridges in my printer. And the ink charged and everything. And now it says its ready to print. But when I try to print something, a pop up shows up and displays the document name of what I want to print, the paper size, whether it is processing or not, the progress, and what time it started printing. But it never begins to print my document. I tried restarting my computer, turning the printer on and off, and unplugging the printer. Please help me.
  • canine Dec 06, 2007
    I added all new cartriges to my all in one and now it doesn't recognize the all new cartriges, Try printing and the pages are blank. My printer says everything is not turned on. Please help. Thanks in advance for your response,
    Al
IDK exactly but i thinks u have to reset it!!
Posted on Mar 21, 2008
    President:
  • 2,961 Answers
In some printer drivers you have to use the their software to inform that you have fitted new cartridges in a form of installation wizard, so assuming you have done that the power aready light on printer should be steady. If not there will be a hardware or software fault, so to determine:- Disconnect printer from usb port and mains Go to printer and faxes in control panel, find the Epson printer icon and right click and delete. Restart pc and reconnect printer to a different usb port if possible, this should then be recognised by windows and either automatically install the driver or ask for your cd rom with driver on. The other way is to install the driver first and then reconnect printer when prompted it depends on model. If still no printing, then there is a problem with the printer itself, which can by an expensive repair, unless you purchase a new one which may be cheaper. I don't know what it is with Epson, i have had two and both after a few cartridge replacements have either refused to print or unable to use all the color cartridges.
Posted on Apr 13, 2007
Changing the ink cartridges?
I have an epson (2 of them). I have to raise the lid and then hold in on the color button for about 6 seconds. Yours should work similar to mine.
Jul 23, 2010 | Epson Stylus CX7800 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Lcd screen says no ink but they are full/new
You might have to pull out your cartridge/s and try dabbing the spot where the ink comes out (on the printer - not on the cartridge) lightly - with a Q-tip dipped in isopropyl alcohol.
How long ago was it since you last used your printer? These types of printers don't like to sit for more than a week or two without you printing at least one page on them.
Sep 24, 2009 | Epson Stylus CX7800 All-In-One InkJet...
How do i change cartridges in epson stylus sx205?
The SX205 is a bit of a pain to use. There doesn't seem to be a way of changing an ink cartridge unless the printer decides it wants to let you. I managed it by employing fairly brutal tactics. I opened the lid to expose the works, switched the printer on, and with my finger over the switch at the mains socket I waited while the printer went through its start-up procedure, then when the ink carrier was in the right position to make a change, I quickly switched the power off. You have to be really quick to catch it in the right position, and you might need to try more than once to get it right. After changing the cartridge, I switched the mains back on, then switched the printer back on, and everything worked OK after that. It seems crazy that Epson hasn't incorporated a way of doing this into the design. Its certainly the worst Epson printer I have owned from the point of view of ease of use. Photos from it aren't very good either. Dinty
Feb 18, 2009 | Epson Stylus CX7800 All-In-One InkJet...
When i print i have lots of lines in the pics!!
These lines are caused by the printheads being clogged. I recommend trying to clean them with rubbing alcohol. Epson printers have a habit of the heads drying out.
As a last resort.... you could pull the cartridges and place a drop or 2 of alcohol into the holes where the cartridges connect to the printheads. Don't put the alcohol in the cartridge themselves as this will dilure the ink.
Feb 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
My ink cartridges are full but the CX7800 says thay are empty.
To check if the waste pad is the culprit you would normally get an error message from the status monitor software or on the printer itself telling you that a service was required or parts have reached the end of their service life.
If that's true you can further confirm it by resetting the waste ink counter using a reset utility.
If you're in North America and have the serial number (usually printed on a label on the back) you can go to this site:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
... and fill out the form (making sure you read the warnings and small print) and request the utility for your model.
If you're OUTSIDE of North America then the SSC utility will also work (google: "ssc epson reset") using the protection counter functions.
At this point, because I don't know that particular model personally I couldn't say with any certainty that the problem is the waste ink pads but it can't hurt to try.
Hope this helps.
Not recognizing ink
Hi there
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Aug 23, 2008 | Epson CX7800 Stylus Color All-In-One...
Epson Stylus CX7800 doesn't recognize new cartridges
I'm not familiar with your model but Epson has used a very durable ceramic printhead that had a fatal flaw; it wants to be used often, otherwise it clogs beyond restoration.
I have had to junk a number of Epsons (and some rebranded ones too) because of clogged printheads.
They work fine for a long time IF used daily.
The record was one branded Texas Instruments which died after not being used for 2 WEEKS.
I customarily recommended them for hard use but not for home users.
Apr 26, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
